An overview of the Conflation toolset
The Conflation toolset contains tools that are used to find spatially matched features and improve positional accuracy of the features through spatial adjustments or transferring attributes from one dataset to another.
GIS data often comes from many sources. Spatial and attribute differences among various data sources sometimes requires resolving the inconsistencies before using the data. Use the tools in the Conflation toolset to reconcile data from multiple sources and obtain the best possible data quality for analysis and mapping.
Some data is geometrically distorted or shifted with respect to the data you maintain or want to use. Use the conflation tools to improve the positional accuracy of the data through spatial adjustments, edgematching, and rubber sheeting. These tools automatically find spatially corresponding features from input datasets, generate edgematch links or rubber sheet links, and perform edgematching or rubber sheeting adjustment using these links. You can also transfer feature attributes from one source of features to matching features of another source.
Tool
Align Features
Identifies inconsistent portions of the input features compared to target features within a search distance and aligns them with the target features.
Calculate Transformation Errors
Calculates residue errors and the root mean square error (RMSE) based on the coordinates of the input links between known control points to be used for spatial data transformation.
Edgematch Features
Modifies input line features by spatially adjusting their shapes, guided by the specified edgematch links, so they become connected with the lines in the adjacent dataset.
Generate Edgematch Links
Finds matching but disconnected line features along the edges of the source data's area and its adjacent data's area, and generates edgematch links from the source lines to the matched adjacent lines.
Generate Rubbersheet Links
Finds where the source line features spatially match the target line features and generates lines representing links from source locations to corresponding target locations for rubbersheeting.
Rubbersheet Features
Modifies input features by spatially adjusting them through rubbersheeting, using the specified rubbersheet links, so they are better aligned with the intended target features.
Split Line By Match
Splits features based on matching relationships to obtain better corresponding line segmentation.
Transfer Attributes
Finds where the source line features spatially match the target line features and transfers specified attributes from source features to matched target features.
Transform Features
Converts the coordinates of input features from one location to another through scaling, shifting, and rotating based on the transformation links between known corresponding control points.
Tools in the Conflation toolset
