Transfer Attributes (Editing Tools)
Summary
Finds where the source line features spatially match the target line features and transfers specified attributes from source features to matched target features.
Attribute transfer is typically used to copy attributes from features in one dataset to corresponding features in another dataset. For example, it can be used to transfer the names of road features from a digitized and maintained dataset to features in a new dataset that are newly collected and more accurate. The two datasets are usually referred to as source features and target features. This tool finds corresponding source and target line features within the specified search distance and transfers the specified attributes from source lines to target lines.
Illustration
Transfer Attributes tool illustration
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
All inputs must be in the same coordinate system.
  • The union of input extents is used as the processing extent. The counts of participating source and target features are reported in the processing messages.
  • One or more fields in the Transfer Field(s) parameter must be specified. If a transfer field has the same name as a field from the target feature table, the transfer field will be appended with _1 (or _2, or _3, and so on) to make it unique.
    When multiple source features match one or more target features, the field values from only one of the source features are transferred to the target features. If a source field value is missing, no attribute transfer occurs.
  • The Search Distance parameter is used in finding match candidates. Use a distance large enough to catch most of the shifts between corresponding features, but not too large to cause unnecessary processing of too many candidates and potentially getting wrong matches.
  • The Output Match Table parameter is optional. The match table provides complete feature matching information, including the source and target FIDs, match groups, match relationships, and the level of confidence of the matching derived from spatial and attribute matching conditions. This information can help you understand the match situations and aid in postinspection, postediting, and further analysis. See About feature matching and the match table for details.
  • Use the Transfer Rule Field(s) parameter to set rules to control attribute transfer for m:n matches in which multiple source features matched one or more target features. If no rules are set, attributes will be transferred from the longest of the matched source features. However, to better guide the transfer, attribute-based rules can be used, and each is defined by a field name and a value.
    The following field types and ruling values are supported:
    Field type
    Ruling values
    Text
    A string value that may exist in the source features.
    Integer
    Either an integer value that may exist in the source features, or MAX or MIN for the maximum or minimum value.
    Date
    MAX or MIN for the most recent or oldest date.
    You can specify as many field/ruling value pairs as needed. The rules will be applied in the order they are listed.
    When an m:n match is found, the tool will check the specified fields and ruling values and determine from which of them to transfer attributes in the following ways:
    • If only one of the m source features has the ruling value in the first field in the rule list, that source feature will be used for the transfer.
    • If more than one, or none, of the m source features have the ruling value, it is a tie. If no more rules are specified, the longest of them will be used for the transfer. Otherwise, the next rule in the list will be checked to break the tie.
    • The process continues until all the rules have been evaluated. If no source feature can be determined for the transfer, the longest source feature will be used.
    The following example explains how this process works. The ROAD_NAME field needs to be transferred from source to target for a 3:1 match. By default, source feature 3, the longest of the three source features, would be used for the transfer, and the target feature would receive the ROAD_NAME value of West Ave as shown in table (a) below.
    Now, assume that the following rules are set: the TRAVEL_DIRECTION field with the One way rule and the SPEED_LIMIT field with the MAX rule. To determine the correct source feature for the transfer, the tool first evaluates the TRAVEL_DIRECTION values for all three source features and finds that two have a match for One way. The tool then checks the SPEED_LIMIT values of these two features and uses the OBJECTID field 1, which has a maximum value of 40. That means the ROAD_NAME field value East Ave is transferred from this feature to the target feature as shown in table (b) below.
    Transfer rule fields example
  • Feature matching accuracy relies on data quality, complexity, and similarities of the two inputs.
    Minimize data errors and select relevant features as input through preprocessing. In general, it is helpful when the features in an input dataset are topologically correct, have valid geometry, and are singlepart and not duplicate; otherwise, unexpected results may occur.
Parameters
Label Explanation Data type
Source Features
The line features from which attributes will be transferred.
Feature Layer
Target Features
The line features to which attributes will be transferred. The transfer fields will be added to the target features.
Feature Layer
Transfer Field(s)
A list of source fields that will be transferred to target features. At least one field must be provided.
Field
Search Distance
The distance that will be used to search for match candidates. A distance must be specified and it must be greater than zero. You can choose a preferred unit. The default is the feature unit.
Linear Unit
Match Fields
(Optional)
Lists of fields from source and target features. If provided, each pair of fields are checked for match candidates to help determine the right match.
Value table columns:
  • Source Fields—Field(s) from source features
  • Target Fields—Field(s) from target features
Value Table
Output Match Table
(Optional)
The output table containing complete feature matching information.
Table
(Optional)
The rules that control which source feature will be used to transfer attributes from when multiple source features matched target features. The source feature that will be used for the transfer is determined by the specified rule fields and the ruling values, which are ranked from high to low priority as they appear in the specified list. If no rules are set, the longest of the multiple matched source features will be used for the transfer.
Available rule types are as follows:
  • MIN—The minimum value for an integer or date field. For a date field, use the most recent date.
  • MAX—The maximum value for an integer or date field. For a date field, use the oldest date.
  • A text or integer value that may exist in the source features.
  • Field—Field(s) from source features
  • Rule—Rules to guide attribute transfer from multiple matched source features
    • Minimum—The minimum value for an integer or date field. For a date field, the most recent date.
    • Maximum—The maximum value for an integer or date field. For a date field, the oldest date.
Value Table
Derived output
Updated Target Features
The updated target features.
Feature Class
Environments
Current Workspace, Extent
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
