Calculate Transformation Errors (Editing Tools)
Summary
Calculates residue errors and the root mean square error (RMSE) based on the coordinates of the input links between known control points to be used for spatial data transformation.
Usage
  • This tool is used before the Transform Features tool to determine whether the control points are suitable for the intended transformation, especially before you transform a large number of features.
  • Input link features are lines representing transformation links between corresponding control points.
  • The transformation works in a Cartesian or planar coordinate system. A projected coordinate system (PCS) is recommended. Using a geographic coordinate system (GCS) with values in latitude and longitude may result in distortion or cause calculation errors.
  • Errors will be calculated for one of the three transformation methods: affine, similarity, and projective. Each method requires a minimum number of transformation links. See Transform a feature for details, including transformation formulas.
    • AFFINE—Requires a minimum of three transformation links
    • PROJECTIVE—Requires a minimum of four transformation links
    • SIMILARITY—Requires a minimum of two transformation links
  • The transformation result depends on the quality of the input links. A link should start from a known source location and end at its corresponding destination location, also called control points. The better established the control points, the more accurate the transformed result. The coordinates of the from and to locations of the links will be used to derive the parameters used in transformation equations, which are a best fit between the source and destination control points as described in Transform features. Even if you use the transformation parameters to transform the actual source control points, the resulting locations won't match the destination control point locations. This is called the residual error and it is generated for each transformation link. The residual errors for input links will be written to the specified output table that contains the following fields:
    • Orig_FID—The input link feature ID
    • X_Source—The x-coordinate of the source or from the end location of the link
    • Y_Source—The y-coordinate of the source or from the end location of the link
    • X_Destination—The x-coordinate of the destination or to the end location of the link
    • Y_Destination—The y-coordinate of the destination or to the end location of the link
    • Residual_Error—The residual error of the transformed location
    A RMSE, also known as root mean square deviation (RMSD), will be calculated based on the residual errors and indicates the general suitability of the derived transformation. The RMSE value is written out in the processing messages. It is also a derived output parameter that you can use in a script or model workflow.
    The Transform features topic provides details regarding the calculations of residual errors and RMSE. You must determine the acceptable RMSE value based on your knowledge of the positional accuracy of the input features as well as the control points. If the RMSE value is too high, review the residual errors and discard or replace the links that have high residual errors.
Parameters
Label Explanation Data type
Input Link Features
The input link features that link known control points for spatial transformation.
Feature Layer
Output Link Table
(Optional)
The output table containing the input links feature IDs and their residual errors. The residual errors for input links will be written to the specified output table that contains the following fields:
Table
Method
(Optional)
Specifies the transformation method that will be used to convert the input feature coordinates.
  • Affine transformation—A minimum of three transformation links is required. This is the default.
  • Projective transformation—A minimum of four transformation links is required.
  • Similarity transformation—A minimum of two transformation links is required.
String
Derived output
RMSE
Reports the root mean square error (RMSE) value.
Double
Environments
Current Workspace, Extent
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
