Transform Features (Editing Tools)
Summary
Converts the coordinates of input features from one location to another through scaling, shifting, and rotating based on the transformation links between known corresponding control points.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
All inputs must be in the same coordinate system.
  • Input features can be points, lines, polygons. or annotations.
  • Input link features are lines representing transformation links between known corresponding control points. The starting point of a link is the source control point location and the endpoint of the link is the corresponding target control point location.
  • The transformation works in a Cartesian or planar coordinate system. A projected coordinate system (PCS) is recommended. Using a geographic coordinate system (GCS) with values in latitude and longitude may result in distortion or cause calculation errors.
  • All input features are transformed by one of the three transformation methods: affine, similarity, and projective. Each method requires a minimum number of transformation links. See Transform a feature for details, including transformation formulas.
    • AFFINE—Requires a minimum of three transformation links
    • PROJECTIVE—Requires a minimum of four transformation links
    • SIMILARITY—Requires a minimum of two transformation links
  • The transformed result depends on the quality of the input links. A link should start from a known source location and end at its corresponding destination location, also called control points. The better established the control points, the more accurate the transformed result. The coordinates of the from and to locations of the links will be used to derive the transformation parameters, which are a best fit between the source and destination control points. Even if you use the transformation parameters to transform the actual source control points, the resulting locations won't match the destination control point locations. This is called the residual error and it is generated for each transformation link. As an option, the residual errors for input links can be written out to a table that contains the following fields:
    • Orig_FID—The input link feature ID
    • X_Source—The x-coordinate of the source or from the end location of the link
    • Y_Source—The y-coordinate of the source or from the end location of the link
    • X_Destination—The x-coordinate of the destination or to the end location of the link
    • Y_Destination—The y-coordinate of the destination or to the end location of the link
    • Residual_Error—The residual error of the transformed location
    A root mean square error (RMSE), also known as root mean square deviation (RMSD), is calculated based on the residual errors and indicates the general suitability of the derived transformation. The RMSE value is written out in the processing messages. It is also a derived output parameter that you can use in a script or model workflow.
    The Transform features topic provides details regarding the calculations of residual errors and RMSE. You must determine the acceptable RMSE value based on your knowledge of the positional accuracy of the input features as well as the control points. If the RMSE value is too high, review the residual errors and discard or replace the links that have high residual errors.
Parameters
Label Explanation Data type
Input Features
The input features, the coordinates of which will be transformed. They can be points, lines, polygons, or annotations.
Feature Layer
Input Link Features
The input link features that link known control points for the transformation.
Feature Layer
Method
(Optional)
Specifies the transformation method that will be used to convert input feature coordinates.
  • Affine transformation—Aa minimum of three transformation links is required. This is the default.
  • Projective transformation—A minimum of four transformation links is required.
  • Similarity transformation—A minimum of two transformation links is required.
String
Output Link Table
(Optional)
The output table containing the input links and their residual errors.
Table
Derived output
RMSE
Reports the root mean square error (RMSE) value.
Double
Updated Input Features
The updated input features.
Feature Layer
Environments
Current Workspace, Extent
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
