Update COGO (Editing Tools)
Summary
Updates the COGO attributes of COGO-enabled line features to match their line shape geometries.
The following COGO attributes will be updated:
  • Direction
  • Distance
  • Radius
  • Arc Length
Directions, distances, and radii can optionally be scaled and rotated by a ground to grid correction.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
Parameters
Label Explanation Data type
Input Line Features
The COGO-enabled line features that will be updated.
Feature Layer
Update Distance, Radius, and Arc Length
(Optional)
Specifies how the input line's Distance, Radius, and Arc Length COGO attributes will be updated.
  • Overwrite all values—All values (including NULL values) will be updated to match the shape length. This is the default.
  • Update NULL values only—Only NULL values will be updated to match the shape length.
  • Update values using a minimum difference—Values that differ from the shape length by more than the specified tolerance will be updated to match the shape length.
  • Do not update any values—Values will not be updated.
String
Minimum Distance Difference
(Optional)
The minimum distance difference between the line shape length and the value in the Distance, Radius, and Arc Length fields. If the difference in the distances is larger than the specified tolerance, the attribute value in the Distance, Radius, or Arc Length fields will be updated to match the line shape length. The default value is 0 meters.
Linear Unit
Update Directions
(Optional)
Specifies how the input's Direction COGO attributes will be updated.
  • Overwrite all values—All values (including NULL values) will be updated to match shape direction. This is the default.
  • Update NULL values only—Only NULL values will be updated to match the shape direction.
  • Update values using a minimum difference—Values that differ from the shape direction by more than the specified tolerance will be updated to match the shape direction.
String
Minimum Direction Difference (seconds)
(Optional)
The minimum direction difference (in seconds) between the line shape direction and the value in the Direction field. If the difference in the directions is larger than the specified tolerance, the attribute value in the Direction field will be updated to match the line shape direction. The default value is 0.
Double
Minimum Direction Lateral Offset
(Optional)
The minimum allowable distance between the endpoint of the line shape and the endpoint of the line drawn using the value in the Direction field. A lateral offset tolerance can be used for very long lines in which small changes in direction can result in large differences in line endpoints. The default value is 0 meters.
Linear Unit
Combined Scale Factor
(Optional)
A scale factor based on a ground to grid correction that will be applied to the line's shape length. The scale factor can be provided as a number or derived from an Arcade expression using the line's attribute fields. The updated distance populated in the Distance, Radius, and Arc Length fields is a result of the shape length multiplied by the scale factor.
Calculator Expression
Direction Offset (seconds)
(Optional)
A rotation based on a ground to grid correction that will be applied to the line's shape direction. The rotation offset can be provided as a value in seconds or derived from an Arcade expression using the line's attribute fields. The updated direction populated in the line's Direction field is the line shape direction rotated by the specified direction offset.
Derived output
Updated Line Features
The updated line features.
Parcel Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
