Neighborhood Selection (Geostatistical Analyst Tools)
Summary
Creates a layer of points based on a user-defined neighborhood.
For example, you can create a selection of points in a circular neighborhood around a location defined by the input point.
Illustration
Neighborhood Selection tool illustration
The output layer contains a selection of 10 blue points.
Usage
Parameters
Label Explanation Data type
Input point features
The points that will be used to create a neighborhood selection.
Feature Layer
Output layer
An output layer with the neighborhood selection.
Feature Layer
Input point
The neighborhood center's x,y-coordinate.
Point
Maximum neighbors to include
The number of points that will be used in each sector. If a sector has the required number of points, all points in that sector will be used.
Long
Include at least
The minimum number of points that will be used in each sector. If the minimum number of required points are not available in any given sector, the nearest available point outside the sector will be selected.
Long
Minor semiaxis
The size of the minor semiaxis of the search neighborhood.
Double
Major semiaxis
The size of the major semiaxis of the search neighborhood.
Double
Angle
The angle of rotation of the neighborhood axis.
Double
Shape type
(Optional)
Species the geometry of the neighborhood.
  • One sector—The neighborhood will be a single ellipse.
  • Four sectors—The neighborhood will be an ellipse divided into four sectors.
  • Four shifted sectors—The neighborhood will be an ellipse divided into four sectors and shifted 45 degrees.
  • Eight sectors—The neighborhood will be an ellipse divided into eight sectors
String
Environments
Current Workspace
Licensing information
  • Basic: Requires Geostatistical Analyst
  • Standard: Requires Geostatistical Analyst
  • Advanced: Requires Geostatistical Analyst
