An overview of the Interpolation toolset
Available with Geostatistical Analyst license.
The Interpolation toolset contains tools that predict values at unmeasured locations.
Tool
Diffusion Interpolation With Barriers
Interpolates a surface using a kernel that is based upon the heat equation and allows one to use raster and feature barriers to redefine distances between input points.
EBK Regression Prediction
EBK Regression Prediction is a geostatistical interpolation method that uses Empirical Bayesian Kriging with explanatory variable rasters that are known to affect the value of the data that you are interpolating. This approach combines kriging with regression analysis to make predictions that are more accurate than either regression or kriging can achieve on their own.
Empirical Bayesian kriging is an interpolation method that accounts for the error in estimating the underlying semivariogram through repeated simulations.
Empirical Bayesian Kriging 3D
Interpolates 3D points using Empirical Bayesian Kriging methodology. All points must have x-, y-, and z-coordinates and a measured value to be interpolated. The output is a 3D geostatistical layer that calculates and renders itself as a 2D transect at a given elevation. The elevation of the layer can be changed using the range slider, and the layer will update to show the interpolated predictions for the new elevation.
Global Polynomial Interpolation
Fits a smooth surface that is defined by a mathematical function (a polynomial) to the input sample points.
IDW
Uses inverse distance weighted interpolation to predict a value for any unsampled location using the measured values surrounding the prediction location. The tool uses the assumption that things that are close to one another are more alike than those that are farther apart.
IDW 3D
Interpolates the values of 3D points using inverse distance weighting (IDW) and creates a voxel layer and source file (.nc) of the predicted values.
Kernel Interpolation With Barriers
A moving window predictor that uses the shortest distance between points so that points on either side of the line barriers are connected.
Local Polynomial Interpolation
Fits the specified order (zero, first, second, third, and so on) polynomial, each within specified overlapping neighborhoods, to produce an output surface.
Moving Window Kriging
Recalculates the Range, Nugget, and Partial Sill semivariogram parameters based on a smaller neighborhood, moving through all location points.
Nearest Neighbor 3D
Creates a voxel layer source file (netCDF) from categorical 3D points by assigning each voxel the categories of the nearest neighbor in 3D.
Radial Basis Functions
Uses one of five basis functions to interpolate a surfaces that passes through the input points exactly.
Tools in the Interpolation toolset
