Local Polynomial Interpolation (Geostatistical Analyst Tools)
Summary
Fits the specified order (zero, first, second, third, and so on) polynomial, each within specified overlapping neighborhoods, to produce an output surface.
How Local Polynomial Interpolation works
Usage
  • Use Local Polynomial Interpolation when your dataset exhibits short-range variation.
  • Global Polynomial Interpolation is useful for creating smooth surfaces and identifying long-range trends in the dataset. However, in earth sciences, the variable of interest usually has short-range variation in addition to long-range trend. When the dataset exhibits short-range variation, Local Polynomial Interpolation maps can capture the short-range variation.
Parameters
Label Explanation Data type
Input features
The input point features containing the z-values to be interpolated.
Feature Layer
Z value field
Field that holds a height or magnitude value for each point. This can be a numeric field or the Shape field if the input features contain z-values or m-values.
Field
Output geostatistical layer
(Optional)
The geostatistical layer produced. This layer is required output only if no output raster is requested.
Geostatistical Layer
Output raster
(Optional)
The output raster. This raster is required output only if no output geostatistical layer is requested.
Raster Dataset
Output cell size
(Optional)
The cell size at which the output raster will be created.
This value can be explicitly set in the Environments by the Cell Size parameter.
If not set, it is the shorter of the width or the height of the extent of the input point features, in the input spatial reference, divided by 250.
Analysis Cell Size
Order of polynomial
(Optional)
The order of the polynomial.
Long
Search neighborhood
(Optional)
Defines which surrounding points will be used to control the output. Standard is the default.
Standard
  • Major semiaxis—The major semiaxis value of the searching neighborhood.
  • Minor semiaxis—The minor semiaxis value of the searching neighborhood.
  • Angle—The angle of rotation for the axis (circle) or semimajor axis (ellipse) of the moving window.
  • Max neighbors—The maximum number of neighbors that will be used to estimate the value at the unknown location.
  • Min neighbors—The minimum number of neighbors that will be used to estimate the value at the unknown location.
  • Sector Type—The geometry of the neighborhood.
    • One sector—Single ellipse.
    • Four sectors—Ellipse divided into four sectors.
    • Four sectors shifted—Ellipse divided into four sectors and shifted 45 degrees.
    • Eight sectors—Ellipse divided into eight sectors.
Smooth
  • Smoothing factor—The Smooth Interpolation option creates an outer ellipse and an inner ellipse at a distance equal to the Major Semiaxis multiplied by the Smoothing factor. The points that fall outside the smallest ellipse but inside the largest ellipse are weighted using a sigmoidal function with a value between zero and one.
Standard Circular
  • Radius—The length of the radius of the search circle.
Smooth Circular
Geostatistical Search Neighborhood
Kernel function
(Optional)
The kernel function used in the simulation.
  • Exponential—The function grows or decays proportionally.
  • Gaussian—Bell-shaped function that falls off quickly toward plus or minus infinity.
  • Quartic—Fourth-order polynomial function.
  • Epanechnikov—A discontinuous parabolic function.
  • Fifth-order polynomial—Fifth-order polynomial function.
  • Constant—An indicator function.
String
Bandwidth
(Optional)
Used to specify the maximum distance at which data points are used for prediction. With increasing bandwidth, prediction bias increases and prediction variance decreases.
Double
Use spatial condition number threshold
(Optional)
Option to control the creation of prediction and prediction standard errors where the predictions are unstable. This option is only available for polynomials of order 1, 2, and 3.
  • Checked—Prediction and prediction standard errors will not be created where the predictions are unstable.
  • Unchecked—Predictions will be created everywhere, including areas where the predictions are unstable. This is the default.
Boolean
Spatial condition number threshold
(Optional)
Every invertible square matrix has a condition number that indicates how inaccurate the solution to the linear equations can be with a small change in the matrix coefficients (it can be due to imprecise data). If the condition number is large, a small change in the matrix coefficients results in a large change in the solution vector.
Double
Weight field
(Optional)
Used to emphasize an observation. The larger the weight, the more impact it has on the prediction. For coincident observations, assign the largest weight to the most reliable measurement.
Field
Output surface type
(Optional)
Surface type to store the interpolation results.
  • Prediction—Prediction surfaces are produced from the interpolated values.
  • Standard error of prediction—Standard Error surfaces are produced from the standard errors of the interpolated values.
  • Condition number—The Spatial condition number surface indicates the stability of calculations at a particular location. The larger the condition number, the more unstable the prediction, so locations with large condition numbers may be prone to artifacts and erratic predicted values.
String
Environments
Cell Size, Coincident Points, Current Workspace, Extent, Geographic Transformations, Mask, Output Coordinate System, Parallel Processing Factor, Snap Raster
Licensing information
  • Basic: Requires Geostatistical Analyst
  • Standard: Requires Geostatistical Analyst
  • Advanced: Requires Geostatistical Analyst
