An overview of the Geostatistical Analyst toolbox
Available with Geostatistical Analyst license.
With Geostatistical Analyst, you can easily create a continuous surface or map from measurements stored in a point feature layer or raster layer or by using polygon centroids. The sample points may be measurements such as elevation, depth to the water table, or levels of pollution. Geostatistical Analyst provides a comprehensive set of tools for creating surfaces that can be used to visualize, analyze, and understand spatial phenomena.
Toolsets |
Description |
The Interpolation toolset contains tools that predict values at unmeasured locations. |
Contains tools used to assist in the placement of new sampling sites. The Densify Sampling Network tool can also be used to determine which sampling sites are no longer required. |
Tools in this toolset are used to perform geostatistical simulations and to assist in the analysis of the results. |
The Utilities toolset contains tools for preprocessing and postprocessing data when developing interpolation models. |
This toolset contains tools used to create, modify, export, and manipulate the properties of a geostatistical layer. |
