Empirical Bayesian Kriging (Geostatistical Analyst Tools)
Summary
Empirical Bayesian kriging is an interpolation method that accounts for the error in estimating the underlying semivariogram through repeated simulations.
What is Empirical Bayesian Kriging?
Usage
  • This kriging method can handle moderately nonstationary input data.
  • Only Standard Circular and Smooth Circular Search neighborhoods are allowed for this interpolation method.
  • The Smooth Circular option for Search neighborhood will substantially increase the execution time.
  • The larger the Maximum number of points in each local model and Local model overlap factor values, the longer the execution time. Applying a Data transformation will also significantly increase execution time.
  • To avoid running out of memory, the software may limit the number of CPU cores that can be used for parallel processing.
  • If the input data is in a geographic coordinate system, all distances will be calculated using chordal distances. For more information on chordal distances, see the Distance calculations for data in geographic coordinates section of the on the What is Empirical Bayesian Kriging help topic.
Parameters
Label Explanation Data type
Input features
The input point features containing the z-values to be interpolated.
Feature Layer
Z value field
Field that holds a height or magnitude value for each point. This can be a numeric field or the Shape field if the input features contain z-values or m-values.
Field
Output geostatistical layer
(Optional)
The geostatistical layer produced. This layer is required output only if no output raster is requested.
Geostatistical Layer
Output raster
(Optional)
The output raster. This raster is required output only if no output geostatistical layer is requested.
Raster Dataset
Output cell size
(Optional)
The cell size at which the output raster will be created.
This value can be explicitly set in the Environments by the Cell Size parameter.
If not set, it is the shorter of the width or the height of the extent of the input point features, in the input spatial reference, divided by 250.
Analysis Cell Size
Data transformation type
(Optional)
Type of transformation to be applied to the input data.
  • None—Do not apply any transformation. This is the default.
  • Empirical—Multiplicative Skewing transformation with Empirical base function.
  • Log empirical—Multiplicative Skewing transformation with Log Empirical base function. All data values must be positive. If this option is chosen, all predictions will be positive.
String
(Optional)
The input data will automatically be divided into groups that do not have more than this number of points.
Long
Local model area overlap factor
(Optional)
A factor representing the degree of overlap between local models (also called subsets). Each input point can fall into several subsets, and the overlap factor specifies the average number of subsets that each point will fall into. A high value of the overlap factor makes the output surface smoother, but it also increases processing time. Typical values vary between 0.01 and 5.
Double
Number of simulated semivariograms
(Optional)
The number of simulated semivariograms of each local model.
Long
Search neighborhood
(Optional)
Defines which surrounding points will be used to control the output. Standard Circular is the default.
Standard Circular
  • Max neighbors—The maximum number of neighbors that will be used to estimate the value at the unknown location.
  • Min neighbors—The minimum number of neighbors that will be used to estimate the value at the unknown location.
  • Sector Type—The geometry of the neighborhood.
    • One sector—Single ellipse.
    • Four sectors—Ellipse divided into four sectors.
    • Four sectors shifted—Ellipse divided into four sectors and shifted 45 degrees.
    • Eight sectors—Ellipse divided into eight sectors.
  • Angle—The angle of rotation for the axis (circle) or semimajor axis (ellipse) of the moving window.
  • Radius—The length of the radius of the search circle.
Smooth Circular
  • Smoothing factor—The Smooth Interpolation option creates an outer ellipse and an inner ellipse at a distance equal to the Major Semiaxis multiplied by the Smoothing factor. The points that fall outside the smallest ellipse but inside the largest ellipse are weighted using a sigmoidal function with a value between zero and one.
Geostatistical Search Neighborhood
Output surface type
(Optional)
Surface type to store the interpolation results.
  • Prediction—Prediction surfaces are produced from the interpolated values.
  • Standard error of prediction—Standard Error surfaces are produced from the standard errors of the interpolated values.
  • Probability—Probability surface of values exceeding or not exceeding a certain threshold.
  • Quantile—Quantile surface predicting the specified quantile of the prediction distribution.
String
Quantile value
(Optional)
The quantile value for which the output raster will be generated.
Double
Probability threshold type
(Optional)
Specifies whether to calculate the probability of exceeding or not exceeding the specified threshold.
  • Exceed—Probability values exceed the threshold. This is the default.
  • Not exceed—Probability values will not exceed the threshold.
String
(Optional)
The probability threshold value. If left empty, the median (50th quantile) of the input data will be used.
Double
Semivariogram model type
(Optional)
The semivariogram model that will be used for the interpolation.
The available choices depend on the value of the Data transformation type parameter.
If the transformation type is set to None, only the first three semivariograms are available. If the type is Empirical or Log empirical, the last six semivariograms are available.
For more information about choosing an appropriate semivariogram for your data, see the topic What is Empirical Bayesian Kriging.
  • Power—Power semivariogram
  • Linear—Linear semivariogram
  • Thin plate spline—Thin Plate Spline semivariogram
  • Exponential—Exponential semivariogram
  • Exponential detrended—Exponential semivariogram with first order trend removal
  • Whittle—Whittle semivariogram
  • Whittle detrended—Whittle semivariogram with first order trend removal
  • K-Bessel—K-Bessel semivariogram
  • K-Bessel detrended—K-Bessel semivariogram with first order trend removal
String
Environments
Cell Size, Coincident Points, Current Workspace, Extent, Geographic Transformations, Mask, Output Coordinate System, Parallel Processing Factor, Snap Raster
Licensing information
  • Basic: Requires Geostatistical Analyst
  • Standard: Requires Geostatistical Analyst
  • Advanced: Requires Geostatistical Analyst
