Convert Video Metadata (Image Analyst Tools)
Summary
Prepares a video metadata file for further processing in geospatial video workflows by field matching and converting unit types. Possible fields that require field matching and unit conversion include coordinates, time formats, telemetry data, and elevation information.
Usage
  • This tool is designed for archived video metadata files and does not work with livestreams.
  • The input metadata format is a Comma-Separated Values (.csv) file.
  • Only fields with an unrecognized name or incorrect format need to be matched. All correct data will be copied to the new metadata file.
  • The output .csv metadata and mapping files are correctly structured to be used in workflows with the Video Multiplexer tool and the ArcGIS Video Server.
  • The possible fields to convert and match are listed in the following table with the required units and format:
    Field Name
    Unit and Format
    Precision Timestamp
    Microseconds
    Sensor Latitude
    Degrees
    Sensor Longitude
    Degrees
    Sensor Ellipsoid Height Extended
    Meters
    Sensor True Altitude
    Meters
    Platform Heading Angle
    Degrees
    Platform Pitch Angle
    Degrees
    Platform Roll Angle
    Degrees
    Sensor Relative Roll Angle
    Degrees
    Sensor Relative Elevation Angle
    Degrees
    Sensor Relative Azimuth Angle
    Degrees
    Sensor Horizontal Field of View
    Degrees
    Sensor Vertical Field of View
    Degrees
Parameters
Label Explanation Data type
Input Metadata File
The input metadata file for field mapping and conversion. The only supported file type is a .csv.
File
Output Metadata File
The name of the output metadata file, including the .csv file extension.
File
Output Metadata Mapping File
(Optional)
The .csv file that cross references the metadata field name to the video field name. Each row represents one of the standard metadata parameters, such as sensor latitude. The first two columns contain the information for the tag and MISB parameter name provided in the form. The third column contains the field name as it appears in the source metadata file. When the third column is populated, the tool can match the metadata field names to the proper video metadata tags.
File
Input Field Matching
(Optional)
A multi-column input parameter that allows users to field match and convert fields in the input metadata file to the desired output file. To match or convert input metadata fields, select the desired metadata field, the input metadata field, and input field unit type.
Value table columns:
  • Target Fields—The metadata field name used in the motion imagery tools.
  • Source Fields—The field name coming from the input video metadata that matches the target field.
  • Source Unit—The unit and format of the source field such as feet or meter.
Value Table
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
