An overview of the Motion Imagery toolset
Available with Image Analyst license.
The Motion Imagery toolset contains tools for managing, processing, and analyzing motion imagery and video data.
Tool |
Description |
Prepares a video metadata file for further processing in geospatial video workflows by field matching and converting unit types. Possible fields that require field matching and unit conversion include coordinates, time formats, telemetry data, and elevation information. |
Extracts video frame images and associated metadata from a metadata compliant video stream. The extracted images can be added to a mosaic dataset or other tools and functions for further analysis. |
Creates a geospatially enabled video file from a pre-recorded video without metadata. The telemetry data is generated using additional information such as horizontal field of view, location, far distance and video start time. |
Extracts one or all of the following from a geospatial video with the correct metadata: the platform position, frame center, frame outline, and the video's metadata. The output geometry and attributes are saved as feature classes. |
Creates a single geospatial video file that combines an archived video stream file and a separate associated metadata file synchronized by a time stamp. The process of combining the two files containing the video and metadata files is called multiplexing. |
