Generate Video Metadata (Stationary) (Image Analyst Tools)
Summary
Creates a geospatially enabled video file from a pre-recorded video without metadata. The telemetry data is generated using additional information such as horizontal field of view, location, far distance and video start time.
Usage
This tool is designed for archived video files and does not work with live video streams.
The video formats supported as an input to the tool are listed in the following table:
Extension
AOMedia Video 1 File
.av1Audio Video Interleaved
.aviHLS (Adaptive Bitrate (ABR))
.m3u8MOV file
.movMPEG-2 Transport Stream
.tsMPEG-2 Program Stream
.psM2TS Transport Stream
.m2tsMPEG File
.mpgMPEG-2 File
.mpg2MPEG-2 File
.mp2MPEG File
.mpegMPEG-4 Movie
.mp4MPEG-4 File
.mpg4MPEG-Dash
.mpdVLC (mpeg2)
.mpeg2VLC Media File (mpeg4)
.mpeg4VLC Media File (vob)
.vobWindows Media Video File
.wmvTo compute and display the relative corner points of the video image footprint as a frame outline on the map, you need the essential metadata information listed below and further detailed in the parameter description. When the metadata is complete and accurate, the tool will calculate the video frame corners, and the size, shape, and position of the video frame outline that can then be displayed on a map.
Timestamp
Sensor Location
Sensor Relative Elevation Angle (tilt)
Relative Azimuth Angle
Horizontal Field of View
Vertical Field of View
This is the minimum metadata required to compute the transform between video and map, display the video footprint on the map, and enable other functionality such as digitizing and marking on the video and the map.
The performance of the resulting multiplexed video file depends on the type and quality of the input tool information.
- If the only data available for tool parameters are
Start TimeandSensor Locationthe location will be displayed on the map, but there will be no footprints. Some functionality, such as digitizing features and measuring distance in the video, will not be supported.
Parameters
| Label | Explanation | Data type |
Input Video File |
The input video file for which metadata will be generated and converted to a geospatial video file. The following file types are supported: |
File |
Output Video File |
The name of the output video file ( |
File |
Sensor Location |
The point feature that identifies the geographic position of the sensor. |
Feature Layer |
Start Time |
The timestamp associated with the first frame of the video. The timestamp will be used to align video frames with temporal and spatial data. |
Date |
Output Metadata File (Optional) |
The name of the output metadata file ( |
File |
Tilt (Optional) |
The vertical angle, in degrees, between the sensor pointing direction and the horizontal plane. Positive values indicate upward tilt; negative values indicate downward tilt. |
Double |
Relative Azimuth (Optional) |
The horizontal angle of the sensor measured clockwise from true north. |
Double |
Horizontal Field of View (Optional) |
The total horizontal angular extent of the sensor’s view, measured in degrees. |
Double |
Vertical Field of View (Optional) |
The total vertical angular extent of the sensor’s view, measured in degrees. |
Double |
Far Distance (Optional) |
The maximum range from the sensor to the far limit of the field of view. |
Linear Unit |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires Image Analyst
- Standard: Requires Image Analyst
- Advanced: Requires Image Analyst
