Video Multiplexer (Image Analyst Tools)
Summary
Creates a single geospatial video file that combines an archived video stream file and a separate associated metadata file synchronized by a time stamp. The process of combining the two files containing the video and metadata files is called multiplexing.
Usage
This tool is designed for archived video files and does not work with live video streams.
The format of the video file that will be multiplexed must be one of the supported video formats. The separate metadata file is a comma-separated values (CSV), JSON, or GPS Exchange Format (GPX) file containing the proper field headings and associated values.
The video formats supported as an input to the tool are listed in the following table:
Extension
AOMedia Video 1 File
.av1Audio Video Interleaved
.aviH264 Video File¹
.h264H265 Video File¹
.h265HLS (Adaptive Bitrate (ABR))
.m3u8MOV file
.movMPEG-2 Transport Stream
.tsMPEG-2 Program Stream
.psM2TS Transport Stream
.m2tsMPEG File
.mpgMPEG-2 File
.mpg2MPEG-2 File
.mp2MPEG File
.mpegMPEG-4 Movie
.mp4MPEG-4 File
.mpg4MPEG-Dash
.mpdVLC (mpeg2)
.mpeg2VLC Media File (mpeg4)
.mpeg4VLC Media File (vob)
.vobWindows Media Video File
.wmv¹ Requires multiplexing
The video file output format is
.tsonly.The metadata associated with the video stream file will be used to compute the flight path of the video sensor, the video image frame center, and the four corners of the video frame footprint on the map.
Geospatial video supports the Motion Imagery Standards Board (MISB) specification. The full MISB specification defines many more parameters than those required for traditional full motion video. The MISB parameters provided will be encoded into the final video, including all parameters or a subset thereof.
To compute and display the relative corner points of the video image footprint as a frame outline on the map, you need the 13 essential metadata fields listed below and further detailed in the parameter description. When the metadata is complete and accurate, the tool will calculate the video frame corners, and the size, shape, and position of the video frame outline that can then be displayed on a map.
Precision Timestamp
Sensor Latitude
Sensor Longitude
Sensor Ellipsoid Height, or Sensor True Altitude
Platform Heading Angle
Platform Pitch Angle
Platform Roll Angle
Sensor Relative Roll Angle
Sensor Relative Elevation Angle
Sensor Relative Azimuth Angle
Sensor Horizontal Field of View
Sensor Vertical Field of View
Far Distance
This is the minimum metadata required to compute the transform between video and map, display the video footprint on the map, and enable other functionality such as digitizing and marking on the video and the map.
The values for the metadata fields can be input in the
Multiplexer_Field_Mapping_Template.csvmetadata template file fromC:\Program Files\ArcGIS\Pro\Resources\MotionImagery.The
Multiplexer_Field_Mapping_Template.csvfile contains all the required metadata fields.Only the 13 parameters defined above are needed to create the metadata compliant video file. You do not need to provide all the parameters defined in the MISB specification to create a metadata compliant video file. If additional MISB parameters are provided, they will be encoded into the video file.
The performance of the resulting multiplexed video file depends on the type and quality of the data contained in the metadata file and how accurately the video data and metadata files are synchronized.
If the
Multiplexer_Field_Mapping_Template.csvfile only containsUNIX Time Stamp,Sensor Latitude, andSensor Longitudefields, the location of the sensor will be displayed on the map, but the footprint of the video frames will not be displayed. Some functionality, such as digitizing features and measuring distance in the video, will not be supported.If the time stamp linking the video and metadata is not accurately synchronized, the video footprint and sensor location on the map will be offset from the view in the video player. In this case, use the
Multiplexer_TimeShift_Template.csvtemplate inC:\Program Files\ArcGIS\Pro\Resources\MotionImageryto adjust the timing of the video and metadata.
One set of parameters in the
Multiplexer_Field_Mapping_Template.csvfile includes the map coordinates of the four corners of the video image frame projected to the ground. If the four corner map coordinates are provided, they will be used in creating the video. If the four corner map coordinates are not provided, provide a source for digital elevation model (DEM) data in the Digital Elevation Model parameter, and the tool will compute the video footprint from the required parameters listed above.The accuracy of the video footprint and frame center depends on the accuracy of the DEM data source provided. If you do not have access to DEM data, you can provide an average elevation and unit relative to sea level, such as 15 feet or 10 meters. In the case of a submersible, you can enter -15 feet or -10 meters, for example. Using an average elevation or ocean depth is not as accurate as providing a DEM or bathymetric data. It is recommended that you provide a DEM layer or image service if it is available.
Geospatial video supports Video Moving Target Indicator (VMTI) data, based on object tracking methods in motion imagery. If VMTI data is recorded in a file separate from the associated video file, it can be encoded into the video file using the video multiplexer tool. Geospatial video supports the MISB Video Moving Target Indicator and Track Metadata standard.
Encode the VMTI data into the video by supplying the required VMTI information for the proper video frame using a
.csv,.json, or.gpxmetadata file containing the data for the following fields:LDSVer,TimeStamp,FrameCenterLongitude,FrameCenterLatitude,SensorLongitude,SensorLatitude,vmtilocaldataset5,1546300800231000,-76.1309338,36.91118708,-76.1309338,36.91118708,1 0.9938099 1611919 1815608 1711844;1 0.39056745 1438997 1556213 1496645
The last column,
vmtilocaldataset, contains the detected object's bounding box in which each space-delimited value is defined by three values: Object_ID Confidence_Level Top_Left_Pixel Bottom_Right_Pixel Center_Pixel.You can specify multiple object detections for a given time stamp with a semicolon (
;) delimiter as shown in the example above.Use
MISB Tag74 in theMultiplexer_Field_Mapping_Template.csvfile.
Parameters
| Label | Explanation | Data type |
Input Video File |
The input video file that will be converted to a geospatial video file. The following file types are supported: |
File |
Metadata File |
A Each column in the metadata file represents one metadata field, and one of the columns must be a time reference. The time reference is UNIX time stamp (seconds past 1970) multiplied by one million, which is stored as an integer. The time is stored this way so that any instant in time (down to one millionth of a second) can be referenced with an integer. Consequently, a time difference between two entries of 500,000 represents one half of a second in elapsed time. The first row contains the field names for the metadata columns. These field names are listed in the The metadata field names can be in any order and should be named exactly as listed in the |
File |
Output Video File |
The name of the output video file, including the file extension. The supported output video file is a |
File |
Metadata Mapping File (Optional) |
A This |
File |
Timeshift File (Optional) |
A file containing defined time shift intervals. Ideally, the video images and the metadata are synchronized in time. In this case, the image footprint in the video surrounds features that can be seen in the video image. Sometimes there is a mismatch between the timing of the video and the timing in the metadata. This leads to an apparent time delay between when a ground feature is surrounded by the image footprint and when that ground feature is visible in the video image. If this time shift is observable and consistent, the multiplexer can adjust the timing of the metadata to match the video. If there is a mismatch between the timing of the video and metadata, specify the time shift in the For example, if the video image has a five-second lag for the entire time, the time shift observation file will have one line: If there is a five-second lag at the 0:18 mark of the video, and a nine-second lag at the 2:21 mark of the video, the time shift observation file will have the following two lines:
In this case, the video is shifted differently at the beginning of the video and at the end of the video. You can define any number of time shift intervals in the time shift observation file. |
File |
Digital Elevation Model (Optional) |
The source of the elevation needed for calculating the video frame corner coordinates. The source can be a layer, image service, or an average ground elevation or ocean depth. The average elevation value must include the units of measurement such as meters or feet or other measure of length. The accuracy of the video footprint and frame center depend on the accuracy of the DEM data source provided. It is recommended that you provide a DEM layer or image service. If you do not have access to DEM data, you can provide an average elevation and unit relative to sea level, such as 15 feet or 10 meters. In the case of a submersible, you can enter -15 feet or -10 meters, for example. Using an average elevation or ocean depth is not as accurate as providing a DEM or bathymetric data. To calculate frame corner coordinates, the average elevation value must always be less than the sensor's altitude or depth as recorded in the metadata. For example, if the video was filmed at a sensor altitude of 10 meters and higher, a valid average elevation could be 9 meters or less. If a video was filmed underwater at a depth of -10 meters and deeper, the valid average elevation (relative to sea level) could be -11 or deeper. If the sensor altitude value is less than the average elevation value, the four corner coordinates will not be calculated for that record. If you do not know the average elevation of the project area, use a DEM. |
Raster Layer; Image Service; Linear Unit |
Input Coordinate System (Optional) |
The coordinate system that will be used for the Metadata File parameter value. |
Coordinate System |
Environments
Adjust for Daylight Saving, Time Zone
Licensing information
- Basic: Requires Image Analyst
- Standard: Requires Image Analyst
- Advanced: Requires Image Analyst
