Extract Ocean Winds (Image Analyst Tools)
Summary
Estimates wind direction and magnitude on the ocean surface.
The input is a synthetic aperture radar (SAR) dataset and the output is a two-band raster with U and V components, which provide a map of ocean surface winds.
Usage
  • The Input Radar Data parameter value needs to be calibrated to sigma nought before running this tool. Use the Apply Radiometric Calibration tool to perform this conversion.
  • The Input Radar Data parameter value must be either a dual polarization or quad polarization single look complex (SLC) product. Dual-polarization examples are HH+HV or VV+VH. Quad-polarization examples are HH, HV, VV, and VH.
  • The tool can only detect winds over the ocean surface. If there are any land in the SAR scene, it must be masked out using the Generate Masked SAR Raster tool, before using this tool.
  • To reduce noise within the Input Radar Data parameter value, use either the Remove Thermal Noise or Despeckle tool before running this tool. This will help improve wind extraction performance.
  • To convert the output of this tool from U-V components to a Magnitude-Direction, use the Vector Field raster function.
Parameters
Label Explanation Data type
Input Radar Data
The input SAR dataset.
The input must be either a dual polarization or quad polarization SLC product.
Raster Dataset; Raster Layer
Output Raster
The output two-band raster dataset that has U and V components.
Raster Dataset
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
References
  • Zhang, B., Mouche, A., Lu, Y., Perrie, W., Zhang, G., & Wang, H. (2019). A geophysical model function for wind speed retrieval from C-band HH-polarized synthetic aperture radar. IEEE Geoscience and Remote Sensing Letters, 16(10), 1521–1525. https://doi.org/10.1109/LGRS.2019.2905578.
  • Hersbach, H. (2008). CMOD5.N: A C-band geophysical model function for equivalent neutral wind (ECMWF Technical Memorandum No. 554). European Centre for Medium-Range Weather Forecasts.
  • Zhang, B., Perrie, W., Vachon, P. W., Li, X., Pichel, W. G., Guo, J., & He, Y. (2012). Ocean vector winds retrieval from C-band fully polarimetric SAR measurements. IEEE Transactions on Geoscience and Remote Sensing, 50(11), 4252–4261. https://doi.org/10.1109/TGRS.2012.2194157.
