Remove Thermal Noise (Image Analyst Tools)
Summary
Corrects backscatter disturbances caused by thermal noise in the input synthetic aperture radar (SAR) data, resulting in a more seamless image.
Usage
  • Correcting, or removing, thermal noise is required to normalize the backscatter signal within the entire image, which is essential to both qualitative and quantitative use of SAR data.
  • Thermal noise is most obvious in cross-polarization SAR data, such as VH or HV, and SAR data with low backscatter.
  • This tool does not support a geodatabase as an output location.
Parameters
Label Explanation Data type
Input Radar Data
The input radar data.
Raster Dataset; Raster Layer
Output Radar Data
The thermal noise-corrected radar data.
Raster Dataset
Polarization Bands
(Optional)
The polarization bands that will be corrected.
The first band is selected by default.
Select all polarization bands if the output will be with the SAR Analysis tools.
String
Environments
Cell Alignment, Compression, Current Workspace, NoData, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
