Apply Orbit Correction (Image Analyst Tools)
Summary
Updates the orbital information in the Sentinel-1 synthetic aperture radar (SAR) data using a more accurate orbit state vector (OSV) file.
Orbit files can be downloaded from external sources using the Download Orbit File tool.
Usage
  • For some SAR sensors, data is provided with predicted OSVs. More precise OSVs are updated and provided separately from the SAR data. This tool can be used to correct the OSVs for supported SAR data.
  • Use the Folder parameter to designate an alternative folder location to search for the downloaded orbit state vector files. The default folder is the input radar data .SAFE folder.
Parameters
Label Explanation Data type
Input Radar Data
The input radar data.
Raster Dataset; Raster Layer
Input Orbit File
The input orbit file.
This parameter value will be automatically set if the orbit file is in the .SAFE directory. If the orbit file is not in the .SAFE directory, the path to the correct file must be specified manually.
File
Folder
(Optional)
The alternate folder location that will be searched for the downloaded orbit state vector files. The default folder is the input radar data .SAFE folder.
Folder
Derived output
Output Radar Data
The updated radar metadata file.
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
