Download Orbit File (Image Analyst Tools)
Summary
Downloads the updated orbit files for Sentinel-1 synthetic aperture radar (SAR) data.
This tool uses the orbit type to make a call to the orbit website. Using the SAR metadata, it identifies the appropriate orbit state vector (OSV) file and downloads it to the input SAR data directory.
Three types of OSVs are available for a Sentinel-1 product: predicted, restituted, and precise. Predicted OSVs are provided with the Sentinel-1 Level 1 ground range detected (GRD) and single look complex (SLC) auxiliary products. Restituted OSVs are available through the European Space Agency (ESA) within 3 hours of image acquisition. Precise OSVs are available through ESA within 3 weeks of image acquisition. Sentinel-1 OSV files are downloaded from the Copernicus Data Space Ecosystem.
Usage
  • Use the Username, Password, and Cloud Storage Connection parameters to download orbit state vectors from the Copernicus Data Space Ecosystem. For instructions on how to register for a Copernicus Data Space Ecosystem account and how to generate the S3 credentials, see Access to EO data via S3 on the Copernicus Data Space Ecosystem Documentation Portal.
    Use the generated S3 credentials in the Create Cloud Storage Connection File tool to generate an .acs file for the Cloud Storage Connection parameter. The following parameters must be set in the Create Cloud Storage Connection tool to create an .acs file:
    • Connection File Location
    • Connection File Name
    • Service Provider—AMAZON
    • Access Key ID (Account Name)
    • Secret Access Key (Account Key)
    • Bucket (Container) Name—eodata
    • Service End Point—eodata.dataspace.copernicus.eu
    • Provider Options—Using the AWS_VIRTUAL_HOSTING option equal to FALSE.
  • Use the Folder parameter to designate an alternative folder location to store the downloaded orbit state vector files. The default folder is the input radar data .SAFE folder.
  • If the SAR data was acquired within the last 3 weeks, set the Orbit Type parameter to Sentinel Restituted. This is available 3 hours after data acquisition.
  • To update the SAR data with the OSVs downloaded using this tool, use the Apply Orbit Correction tool.
Parameters
Label Explanation Data type
Input Radar Data
The input radar data.
Raster Dataset; Raster Layer
Orbit Type
(Optional)
Specifies the OSV type that will be downloaded.
  • Sentinel Restituted—Approximate OSV data will be downloaded. This is available several hours after data acquisition.
  • Sentinel Precise—Refined OSV data will be downloaded. This is available 20 days after data acquisition. This is the default.
String
Username
(Optional)
The Copernicus Data Space Ecosystem login credential username.
This parameter is only valid when the input data has Sentinel restituted or Sentinel precise orbit types.
String
Password
(Optional)
The Copernicus Data Space Ecosystem login credential password.
Encrypted String
(Optional)
The Copernicus Data Space Ecosystem cloud storage connection file.
File
Folder
(Optional)
An alternate folder location where the downloaded orbit state vector file will be stored. The default folder is the input radar data .SAFE folder.
Folder
Derived output
Orbit File
The output orbit file.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
