Generate Radiometric Terrain Corrected Data (Image Analyst Tools)
Summary
Transforms Level 1 synthetic aperture radar (SAR) data to a radiometric terrain-corrected (RTC) dataset. Use the RTC data for analysis and visualization.
This tool creates a SAR output that removes unwanted noise and distortions by applying the appropriate RTC workflow according to the input SAR sensor, mode, and product type.
Usage
Parameters
Label Explanation Data type
Input Radar Data
The input radar data.
The input data must be Level 1 radar data.
Raster Dataset; Raster Layer
Output Radar Data
The RTC dataset.
Raster Dataset
DEM Raster
The input DEM.
The DEM that will be used to estimate the local illuminated area and the local incidence angle.
Apply geoid correction
(Optional)
Specifies whether the vertical reference system of the input DEM will be transformed to ellipsoidal height. Most elevation datasets are referenced to sea level orthometric height, so a correction is required in these cases to convert to ellipsoidal height.
  • Checked—A geoid correction will be made to convert orthometric height to ellipsoidal height (based on EGM96 geoid). This is the default.
  • Unchecked—No geoid correction will be made. Use this option only if the DEM is provided in ellipsoidal height.
Boolean
Polarization Bands
(Optional)
The polarization bands that will be filtered.
The first band is selected by default.
Select all polarization bands if the output will be with the SAR Analysis tools.
String
Output Units
(Optional)
Specifies the units that will be used for the RTC outputs.
  • Linear—The units of the output will be in linear backscatter. This is the default.
  • Decibel (dB)—The units of the output will be in decibels.
String
Processing Level
(Optional)
Specifies the radar products that will be retained. The available processing levels depend on the input radar data and its corresponding processing workflow.
By default, no option will be used, and no radar products will be retained.
String
Output Folder
(Optional)
The output folder where the output radar products will be retained.
Workspace
Username
(Optional)
The Copernicus Data Space Ecosystem login credential username.
This parameter is only valid when the input data has Sentinel restituted or Sentinel precise orbit types.
String
Password
(Optional)
The Copernicus Data Space Ecosystem login credential password.
String Hidden
Cloud Storage Connection
(Optional)
The Copernicus Data Space Ecosystem cloud storage connection file.
File
Derived output
Updated Folder
The output folder where the radar products are saved.
Workspace
Environments
Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
