Capella GEC workflow
Available with Image Analyst license.
A Capella synthetic aperture radar (SAR) image must be processed before it can be used for visualization or analysis. Issues to address include calibrating to retrieve a meaningful backscatter value, mitigating speckle, removing radiometric and geometric terrain distortions, and rendering images with a large value range.
The Synthetic Aperture Radar toolset in the Image Analyst toolbox contains the tools described in the table and diagram below that you can use to generate calibrated, terrain-corrected, analysis-ready imagery data from Capella Geocoded Ellipsoid Corrected (GEC) data:
Tool
Apply Radiometric Calibration
Converts the input synthetic aperture radar (SAR) reflectivity into physical units of normalized backscatter by normalizing the reflectivity using a reference plane.
Apply Radiometric Terrain Flattening
Corrects the input synthetic aperture radar (SAR) data for radiometric distortions due to topography.
Despeckle
Corrects the input synthetic aperture radar (SAR) data for speckle, which is a result of coherent illumination that resembles a grainy or salt and pepper effect.
Apply Geometric Terrain Correction
Orthorectifies the input synthetic aperture radar (SAR) data using a range-Doppler backgeocoding algorithm.
Convert SAR Units
Converts the scaling of the input synthetic aperture radar (SAR) data.
Workflow for processing analysis-ready imagery data from Capella GEC data
Capella GEC processing considerations
Capella auxiliary products provide a constant scaling factor to calibrate image values from digital numbers to sigma nought. The Apply Radiometric Calibration tool uses a constant incidence angle value, provided in the Capella auxiliary products, to convert sigma nought values to beta nought or gamma nought values.
Although Capella GEC products have been orthorectified using an ellipsoid, it is recommended that you use the Apply Geometric Terrain Correction tool to orthorectify the data with a digital elevation model. Orthorectifying using a digital elevation model improves the geometric terrain distortion correction for data over land.
