Convert SAR Units (Image Analyst Tools)
Summary
Converts the scaling of the input synthetic aperture radar (SAR) data.
Conversions can be performed between amplitude and intensity, between linear and decibels (dB), between complex and intensity, and between phase and displacement.
Usage
  • This tool simplifies SAR product interpretation and improves image display by reducing the range of amplitude or intensity values through the conversion to a dB value.
  • You can also convert data from amplitude to intensity and vice versa.
  • You can convert complex data to intensity data; however, you cannot convert intensity data back to complex data since the phase information is no longer available.
  • The phase conversions are used for converting unwrapped interferogram radians to topographic metrics. The phase in a single look complex (SLC) input cannot be converted.
  • When the Conversion Type parameter is set to Unwrapped phase to displacement, the output will be rendered using the red-blue continuous color scheme.
  • This tool does not support a geodatabase as an output location.
Parameters
Label Explanation Data type
Input Radar Data
The input radar data.
Raster Dataset; Raster Layer
Output Radar Data
The converted radar dataset.
Raster Dataset
Conversion Type
(Optional)
Specifies the type of backscatter conversion that will be applied.
  • Linear to dB—The unitless values will be converted to dB values. This is the default.
  • dB to linear—The dB values will be converted to unitless values.
  • Amplitude to intensity—The amplitude values will be converted to intensity values by squaring the amplitude.
  • Intensity to amplitude—The intensity values will be converted to amplitude values by applying the square root to the intensity.
  • Complex to intensity—The complex values will be converted to intensity values by adding the square of the real and imaginary components.
  • Unwrapped phase to displacement—The unwrapped interferogram phase in radians will be converted to displacement using the sensor's wavelength.
String
Environments
Cell Alignment, Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
