Non Maximum Suppression (Image Analyst Tools)
Summary
Identifies duplicate features from the output of the Detect Objects Using Deep Learning tool as a postprocessing step and creates a new output with no duplicate features. The Detect Objects Using Deep Learning tool can return more than one bounding box or polygon for the same object, especially as a tiling side effect. If two features overlap more than a given maximum ratio, the feature with the lower confidence value will be removed.
Usage
This tool implements the non-maximum suppression algorithm to delete duplicate objects created by the Detect Objects Using Deep Learning tool.
The feature class must have a confidence field with a confidence value for each feature.
If the feature class contains more than one object class—such as trees, cars, or buildings—it also must have a field with either a class value or a class name.
If two overlapping features have an overlap ratio larger than the Maximum Overlap Ratio specified, the feature with the lower confidence will be removed.
The tool first reviews the feature class for each object class separately, and marks lower confidence duplicate features to be removed. Then it reviews all features, comparing features of different object classes. The output is a new feature class with the detected duplicate features removed.
Parameters
| Label | Explanation | Data type |
Input Feature Class |
The input feature class or feature layer containing overlapping or duplicate features. |
Feature Class; Feature Layer |
Confidence Score Field |
The field in the feature class that contains the confidence scores as output by the object detection method. |
Field |
Output Feature Class |
The output feature class with the duplicate features removed. |
Feature Class |
Class Value Field (Optional) |
The class value field in the input feature class. If not specified, the tool will use the standard class value fields |
Field |
Max Overlap Ratio (Optional) |
The maximum overlap ratio for two overlapping features. This is defined as the ratio of intersection area over union area. The default is 0. |
Double |
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Scratch Workspace
Licensing information
- Basic: Requires Image Analyst
- Standard: Requires Image Analyst
- Advanced: Requires Image Analyst
