Create IPS Data Model (Indoor Positioning Tools)
Summary
Creates an IPS Data Model containing the following components:
IPS Positioning Datasets
IPS Positioning Signals
IPS Positioning Points
IPS Recordings
IPS Beacons
Usage
The Target Workspace parameter value must be an existing geodatabase. The value can be a file or an enterprise geodatabase.
When using an enterprise geodatabase, the connection file must connect directly to the database as the database owner.
If the Setup Indoors Model for IPS parameter is checked, the tool will create and configure the following feature classes from the ArcGIS Indoors Information Model that are essential or recommended to enhance ArcGIS IPS functionality and visualization:
Sites
Facilities
Levels
Units
Details
Pathways
Transitions
The coordinate system of the existing Indoors Information Model will not be modified with this tool. You can select a coordinate system using the Coordinate System parameter for the IPS Data Model.
Parameters
| Label | Explanation | Data type |
Target Workspace |
The file or enterprise geodatabase where the IPS Data Model will be created. |
Workspace |
Coordinate System |
The spatial reference that will be used for the output IPS Data Model. The default is WGS84. |
Coordinate System |
Setup Indoors Model for IPS (Optional) |
Specifies whether an Indoors Information Model containing the feature classes—Sites, Facilities, Levels, Units, Details, Pathways, and Floor Transitions—will be created and configured.
Boolean |
Derived output
Updated Workspace |
The file or enterprise geodatabase where the IPS Data Model is created. |
Workspace |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
