An overview of the Indoor Positioning toolbox
The Indoor Positioning toolbox contains tools to create an ArcGIS IPS Information Model, which enables indoor surveys with the ArcGIS IPS Setup app, processing of survey data, and indoor positioning. The toolbox also includes the Quality Assessment toolset that contains tools to evaluate the performance of an ArcGIS IPS deployment.
Tool |
Description |
Generates traversability information necessary to enable geometry-aided indoor positioning. |
Creates an IPS Data Model containing the following components:
Generates an optimized beacon placement plan by creating point features in an IPS Beacons feature class, ensuring sufficient coverage and spatial distribution with the minimum number of beacons required to enable indoor positioning with ArcGIS IPS. |
Generates the IPS positioning dataset for an existing ArcGIS IPS installation. You can use a survey-based or survey-less method to generate the dataset. |
Publishes an Indoor Positioning Data Service to ArcGIS Enterprise or ArcGIS Online. An Indoor Positioning Data Service contains the data required for enabling indoor positioning. It is used by the |
Toolset |
Description |
The ArcGIS IPS Quality Assessment toolset contains tools that assess the performance of an ArcGIS IPS deployment. |
