Share Indoor Positioning Data Service (Indoor Positioning Tools)
Summary
Publishes an Indoor Positioning Data Service to ArcGIS Enterprise or ArcGIS Online. An Indoor Positioning Data Service contains the data required for enabling indoor positioning. It is used by the IndoorsLocationDataSource objects of the ArcGIS Maps SDKs to compute an estimated position.
Usage
  • The IPS Positioning Datasets parameter value is a polygon feature class created by the Create IPS Data Model tool.
  • The IPS Dataset Name parameter value can be selected from the available names of the datasets in the IPS Positioning Datasets parameter value. The dataset names are stored as feature attributes in the IPS Positioning Datasets parameter value.
  • The Sharing Level parameter is based on user permissions. The available options are Owner, Organization, and Everyone (public) .
  • To update an existing Indoor Positioning Data Service on the portal, check the Update an Existing Indoor Positioning Data Service parameter.
    • If an existing Indoor Positioning Data Service is part of an offline map area, the service cannot be updated. Share a new Indoor Positioning Data Service instead.
    The Title parameter value must match the name of an existing Indoor Positioning Data Service on the signed-in portal that the current user has permissions to update. When updating an existing Indoor Positioning Data Service, the following parameters are hidden:
    • Folder
    • Sharing Level
    • Group Sharing
Parameters
Label Explanation Data type
The feature class from the ArcGIS IPS Data Model containing one feature per Indoor Positioning Dataset.
Feature Layer
IPS Dataset Name
The name of the Indoor Positioning Dataset. Options will be a list of dataset names derived from the IPS Positioning Datasets parameter value.
String
Title
The title of the Indoor Positioning Data Service.
String
Summary
(Optional)
A short description for the Indoor Positioning Data Service.
String
Tags
(Optional)
The keywords or terms that describe the Indoor Positioning Data Service. Separate multiple tags with a comma.
String
Folder
(Optional)
The name of an existing folder on the portal where the Indoor Positioning Data Service will be stored.
String
Sharing Level
(Optional)
Specifies the sharing permissions that will be used for the service.
  • Owner—Only the owner of the Indoor Positioning Data Service will have access. This is the default.
  • Organization—All members of the organization will have access.
  • Everyone (public)—Everyone, including people outside the organization, will have access.
String
Group Sharing
(Optional)
The groups with which the Indoor Positioning Data Service will be shared. You can select multiple values from the groups to which you belong.
String
(Optional)
Specifies whether an existing Indoor Positioning Data Service will be overwritten.
  • Checked—An existing Indoor Positioning Data Service will be overwritten.
  • Unchecked—An existing Indoor Positioning Data Service will not be overwritten, and a new service will be shared. This is the default.
Boolean
Derived output
Indoor Positioning Data Service Item ID
The Indoor Positioning Data Service item ID of the file.
String
Indoor Positioning Data Service Item URL
The Indoor Positioning Data Service URL of the item uploaded to the portal.
String
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Requires ArcGIS IPS
  • Advanced: Requires ArcGIS IPS
