Create IPS Quality Dataset (Indoor Positioning Tools)
Summary
Creates a dataset that can be used to assess the quality of an ArcGIS IPS deployment.
Usage
The Target Workspace parameter value must be an existing geodatabase. The value can be a file or an enterprise geodatabase.
When using an enterprise geodatabase, the connection file must connect directly to the database as the database owner.
The Dataset Name parameter value must be a string that adheres to the dataset naming rules and limitations and is 160 characters or less.
The following feature classes will be created in the output IPS Quality dataset:
Reference Positions—A point feature class that represents the positions of the surveyor at different times as the surveyor proceeds along a Quality IPS recording trajectory.
Computed Positions—A point feature class that represents the positions calculated by the ArcGIS IPS engine during a Quality IPS recording. The computed positions can be matched with the corresponding reference positions by the
Recording GUIDandIPS Timeattributes.
Parameters
| Label | Explanation | Data type |
Target Workspace |
The geodatabase where the IPS Quality dataset will be created. The value can be a file or an enterprise geodatabase. |
Workspace |
Coordinate System |
The spatial reference that will be used for the output IPS Quality dataset. The default is WGS84. |
Coordinate System |
Dataset Name |
The name of the dataset that will be created. The default is IPS_Quality. |
String |
Derived output
Output Dataset |
The IPS Quality dataset that will be created in the target geodatabase. |
Feature Dataset |
Output Reference Positions |
The updated Reference Positions feature class that will be created in the target geodatabase. |
Feature Class |
Output Computed Positions |
The updated Computed Positions feature class that will be created in the target geodatabase. |
Feature Class |
Environments
Licensing information
- Basic: No
- Standard: Requires ArcGIS IPS
- Advanced: Requires ArcGIS IPS
