ArcGIS IPS Information Model
Available for an ArcGIS organization licensed with the ArcGIS IPS extension.
The ArcGIS IPS Information Model supports the management of indoor positioning information required to share properly configured web maps and mobile map packages for use with the ArcGIS IPS Setup app and other ArcGIS IPS-enabled apps. It also contains the data structures required to assess indoor positioning performance.
The ArcGIS IPS model consists of two parts:
  • Core tables and feature classes—The tables and feature classes are required to enable indoor positioning and maintain up-to-date information about the beacon infrastructure.
  • The IPS_Quality dataset—Contains point feature classes that are used to assess the performance of an ArcGIS IPS deployment.
The ArcGIS IPS model can also use the following data from the ArcGIS Indoors Information Model:
  • Floor plan data—Includes the Sites, Facilities, Levels, Units, and Details feature classes that contain floor plan and indoor spaces data.
  • Transitions—In the Indoors model, the Transitions feature class contains features that represent transitions between floors, such as stairs and elevators. The ArcGIS IPS model extends this feature class by using a domain to include transitions between indoor and outdoor spaces.
  • Pathways—Linear features that represent traversable space. When marked for use with the ArcGIS IPS app, path snapping is enabled to enhance positioning accuracy.
Updates to the ArcGIS IPS model
The following table describes the changes that were made to the ArcGIS IPS model in the recent software release:
ArcGIS Pro version
Schema item
Change
3.7
IPS_Beacons_Inventory
New table
IPS_Beacons_Inventory is a table that stores vendor beacon information. It is used by the ArcGIS IPS Setup app during beacon deployment to transfer consistent beacon attributes into the IPS_Beacons feature class.
3.6
IPS_Positioning_Datasets feature class
New field added: GEOMETRY_AIDED
The GEOMETRY_AIDED field indicates whether the dataset contains the connectivity graph.
Enable attachments
The IPS_Beacons feature class stores attachments of images.
3.5
Enable attachments
The IPS_Positioning_Datasets feature class stores attachments that include extra data used by the ArcGIS IPS engine.
3.4
New field added: MAC_ADDRESS
LEVEL_ID field is now nullable.
The MAC address can be retrieved using a Bluetooth scanner or, in some cases, by scanning a QR code on the device.
ArcGIS IPS model
You can use the Create IPS Data Model tool to create the ArcGIS IPS model in an existing Indoors workspace. The ArcGIS IPS model includes the following components that are required to set up and enable the indoor positioning system:
  • Feature classes:
    • IPS_Recordings
    • IPS_Beacons
    • IPS_Positioning_Datasets
    • IPS_Positioning_Points
  • Tables:
    • IPS_Positioning_Signals
    • IPS_Beacons_Inventory
The IPS_Recordings feature class is used to plan and store survey recordings and quality recordings of an indoor environment. Sensor data and its metadata are stored as an attachment on the feature class.
Feature classes
The following table lists the feature classes that are included in the ArcGIS IPS model:
Feature class
IPS_Recordings
A polyline feature class where the ArcGIS IPS Setup app stores indoor positioning survey and quality recordings.
IPS_Beacons
A point feature class that describes the geographic location and attributes of beacons in a facility.
A polygon feature class that represents IPS positioning datasets. Each polygon represents an area's footprint where the dataset can provide indoor positioning. Each feature in this feature class contains one IPS positioning dataset, other attributes describing the dataset, and attachments that include data used by the ArcGIS IPS engine.
A point feature class that stores reference points used for positioning. These points help determine the location of users and enable the location tracker on the map.
IPS_Recordings
The following table lists the fields that are included in the IPS_Recordings feature class:
Field name
Type
Nullable
SITE_ID
Text
True
The unique ID for the feature’s associated site that is used to identify the associated site feature in floor-aware maps. A feature can only be related to a single site using the SITE_ID field.
FACILITY_ID
Text
False
The unique ID for the feature’s associated facility that is used to identify the associated facility feature in floor-aware maps. A feature can only be related to a single facility using the FACILITY_ID field.
LEVEL_ID
Text
False
Records the unique ID of the feature’s associated level. This ID is used to identify the feature’s associated level feature in floor-aware maps. A feature can only be related to a single level in the LEVEL_ID field.
SURVEY_DATE
Date
True
The date the survey path was recorded in the IPS Setup app.
COMMENT
Text
True
The user’s comments about the recording when it was created using the IPS Setup app.
SURVEYOR
Text
True
The username of the user who was signed in to the IPS Setup app when the survey was performed.
DEVICE
Text
True
The device name and model that was used to create the recording.
APP_VERSION
Text
True
The version of the IPS Setup app that was used to create the recording.
RECORDING_TYPE
Text
True
The type of recording.
The DOM_IPS_RECORDING_TYPE domain defines the following allowed field values:
  • Survey = Survey
  • Quality = Quality
BLUETOOTH
Long
True
Indicator of whether the recording contains Bluetooth data.
The DOM_BOOLEAN domain allow the following field views:
  • 0 = False
  • 1 = True
WIFI
Long
True
Indicator of whether the recording contains Wi-Fi data.
The DOM_BOOLEAN domain allows the following field values:
  • 0 = False
  • 1 = True
GLOBALID
Global ID
False
The unique ID for a feature or table row in a geodatabase and across geodatabases. It is a store registry-style string consisting of 36 characters in curly brackets in a geodatabase.
PLANNING_DATE
Date
False
The date the recording path was created. This field is automatically populated by a calculation attribute rule with the current date when a feature is created in the feature class.
IPS_Beacons
The following table lists the fields that are included in the IPS_Beacons feature class:
Field name
Type
Is nullable
VENDOR
Text
True
The name of the beacon vendor.
BEACON_ID
Text
True
A short, alphanumeric string that uniquely identifies a Bluetooth beacon. The format varies by vendor.
UUID
Text
True
A proximity Universally Unique Identifier (UUID) that consists of 32 hexadecimal characters split into five groups separated by hyphens. The length of each group is 8-4-4-4-12; for example, aa72426e-955d-41fb-9aaa-d67c749198a6.
The UUIDs can be generated locally and configured for Bluetooth beacons because there is no central authority or registration.
Based on the iBeacon protocol, the same UUID is associated with a subset of a beacon network and is part of the advertised message.
MAJOR
Long
True
A 2-byte unsigned integer that is associated with a Bluetooth beacon.
Based on the iBeacon protocol, this can further distinguish a group of beacons in a network and is part of the advertised message.
The field must be an integer value between 1 and 65535.
MINOR
Long
True
PROTOCOL
Text
True
The bluetooth protocol used by the beacons. Only iBeacon is supported with the current release.
RSSI_1M
Float
True
The received Signal Strength Indicator (RSSI) at 1 meter distance. Typically, this is configurable for each beacon. The possible values are specified by the beacon vendor.
The field must be an integer value between -120 and 0.
ADVERTISING_INTERVAL_MS
Float
True
The interval in milliseconds at which the beacon broadcasts its messages.
LEVEL_ID
Text
True
BATTERY_LEVEL
Float
True
The residual battery level of the beacon as a percentage of total battery power.
LAST_SEEN
Date
True
The date and time a beacon's signal was last observed.
PLACEMENT_DATE
Date
True
The date and time a beacon was deployed.
GLOBALID
Global ID
False
TRANSMITTER_ID
Text
True
Identifies a specific beacon in a network. It is a combination of UUID, MAJOR, and MINOR for Bluetooth beacons.
MAC_ADDRESS
Text
True
A unique 48-bit identifier assigned to each Bluetooth beacon, typically by the manufacturer.
It is displayed as 6-bytes written in hexadecimal and separated by colons (example: 00:1A:7D:DA:71:13).
The following table lists the fields that are included in the IPS_Positioning_Datasets feature class:
Field name
Type
Is nullable
GLOBALID
Global ID
False
DATASET_NAME
Text
False
The name of the dataset.
DATE_CREATED
Date
False
The date the dataset was created.
BLUETOOTH
Long
False
  • 0 = False
  • 1 = True
WiFi
Long
False
  • 0 = False
  • 1 = True
NOTES
Text
True
The user's notes about the dataset.
GENERATION_METHOD
Short
False
Specifies the type of indoor positioning data generation method as Survey-Based or Survey-Less.
The DOM_IPS_GENERATION_METHOD domain defines the following allowed field values:
  • 0 = Survey-Based
  • 1 = Survey-Less
GEOMETRY_AIDED
Long
False
Indicator of whether the dataset contains the connectivity graph that enables geometry-aided indoor positioning.
  • 0 = False
  • 1 = True
The following table lists the fields that are included in the IPS_Positioning_Points feature class:
Field name
Type
Is nullable
DATASET_GUID
GUID
False
The globally unique ID for of the dataset.
DATASET_NAME
Text
False
GLOBALID
Global ID
False
LEVEL_ID
Text
False
VERTICAL_ORDER
Integer
False
The display and reference order for floors in which the ground level is represented as zero (0). Floor levels above 0 are assigned positive values, and floor levels below 0 are assigned negative values.
Table
The table included in the ArcGIS IPS model is listed below:
Table
A table that stores radio signals used for creating IPS positioning points. Although these signals are not directly used for indoor positioning, they can be used for analysis and evaluation of the indoor positioning data service.
A reference table that stores predefined beacon attributes that the ArcGIS IPS Setup app uses to simplify beacon deployments.
The following table lists the fields that are included in the IPS_Positioning_Signals table:
Field name
Type
Nullable
GLOBALID
Global ID
False
POINT_GUID
GUID
False
The globally unique ID for a specific IPS positioning point.
DATASET_NAME
Text
False
TRANSMITTER_ID
Text
False
The ID for a specific radio source in a network. It can be a combination of UUID, MAJOR, and MINOR for Bluetooth beacons or the MAC address for Wi-Fi access points.
TRANSMITTER_TYPE
Short
False
Specifies the type of transmitter as either Bluetooth or Wi-Fi.
The DOM_SIGNAL_TYPE domain defines the following allowed field values:
  • 0 = Bluetooth
  • 1 = Wi-Fi
RSSI_MEAN
Double
False
The mean or average Received Signal Strength Indicator (RSSI) value. It is calculated using all the identical signals received from the same transmitter for a specific IPS positioning point.
GENERATION_METHOD
Short
False
The type of indoor positioning data generation method as either Survey-Based or Survey-Less.
  • 0 = Survey-Based
  • 1 = Survey-Less
The following table lists the fields that are included in the IPS_Beacons_Inventory table:
Field name
Type
Is nullable
VENDOR
Text
True
BEACON_ID
Text
True
UUID
Text
True
MAJOR
Long
True
MINOR
Long
True
PROTOCOL
Text
True
RSSI_1M
Float
True
Float
True
MAC_ADDRESS
Text
True
BATTERY_LEVEL
Float
True
GLOBALID
Global ID
False
IPS_Quality dataset
You can use the tools in the Quality Assessment toolset to create the IPS_Quality dataset and populate it with data. The Create IPS Quality Dataset tool creates the dataset that stores quality assessment results. The tool also creates the following feature classes in an existing workspace:
  • Reference_Positions
  • Computed_Positions
The Compute Positioning Quality tool transforms quality recordings into reference positions and computed positions features, which encode information about the performance of a deployment. Reference positions denote points that are available for a quality assessment. Computed positions represent the indoor positions generated by the ArcGIS IPS engine for each of these references.
Feature classes
The following table lists the feature classes in the quality dataset:
Feature class
Reference_Positions
A point feature class that contains a surveyor's actual position at a specific time during a quality recording survey.
Computed_Positions
A point feature class that contains a surveyor's computed position based on a specific indoor positioning data service at a specific time during a quality recording survey. The computed positions can be matched with their corresponding reference positions by the RECORDING_GUID and IPS_TIME attributes.
Reference_Positions
The following table lists the fields in the Reference_Positions feature class:
Field name
Type
Is nullable
LEVEL_ID
TEXT
True
RECORDING_GUID
GUID
True
The global ID for the quality recording from which the reference positions feature was generated.
IPS_TIME
DATE
True
The date and time in coordinated universal time (UTC) of the reference positions feature.
POSITIONING_GUID
GUID
True
The global ID of the indoor positioning dataset that was used to perform the quality recording survey that generates the reference positions feature.
BLUETOOTH_POSITIONING
LONG
True
Specifies whether the indoor positioning data service used during the quality recording supports Bluetooth positioning.
The DOM_BOOLEAN domain describes the allowed values:
  • 0 = False
  • 1 = True
WIFI_POSITIONING
LONG
TRUE
Specifies whether the indoor positioning data service used during quality recording supports Wi-Fi positioning.
  • 0 = False
  • 1 = True
DISTANCE_TO_COMPUTED
DOUBLE
True
The distance between the reference position feature and the corresponding computed position feature. When a level mismatch occurs, the value is set to NULL.
ACCURACY_LEVEL
SHORT
True
The calculated accuracy level based on the DISTANCE_TO_COMPUTED field.
The DOM_IPS_QA_ACCURACY_LEVEL domain describes the allowed values:
  • 0 = Invalid
  • 1 = Low
  • 2 = Medium
  • 3 = High
Accuracy level is calculated as follows:
  • Invalid—LEVEL_MATCH is FALSE
  • Low—LEVEL_MATCH is TRUE and DISTANCE_TO_COMPUTED is greater than 10 meters.
  • Medium—LEVEL_MATCH is TRUE and DISTANCE_TO_COMPUTED is between 5 and 10 meters.
  • High—LEVEL_MATCH is TRUE and DISTANCE_TO_COMPUTED is less than 5 meters.
LOS_TO_COMPUTED
LONG
True
Specifies whether the reference positions feature is visible from the matching computed positions feature. The value is TRUE if the reference positions feature is on the same floor as the corresponding computed positions feature and there is no obstacle between them. The value is set to NULL if not computed.
The DOM_BOOLEAN domain allows the following values:
  • 0 = False
  • 1 = True
LEVEL_MATCH
LONG
True
Specifies whether the reference positions feature and the corresponding computed positions feature are on the same level.
  • 0 = False
  • 1 = True
LOCATION_SOURCE
SHORT
True
Specifies the type of positioning source used by the ArcGIS IPS engine to compute the feature during the quality recording.
The DOM_IPS_LOCATION_SOURCE domain allows the following values:
  • 0 = Unknown
  • 1 = Bluetooth
  • 2 = Wi-Fi
  • 3 = GNSS
  • 4 = Apple IPS
Computed_Positions
The following table lists the fields in the Computed_Positions feature class:
Field name
Type
Is nullable
LEVEL_ID
TEXT
True
RECORDING_GUID
GUID
True
The global ID for the quality recording that generated the reference positions feature.
IPS_TIME
DATE
True
The date and time in coordinated universal time (UTC) when the reference positions feature was computed by the ArcGIS IPS engine.
