Prepare and share a map for ArcGIS IPS Setup
Available with Standard or Advanced license.
ArcGIS IPS Setup supports beacon infrastructure deployments and allows facilities to be surveyed using web maps that have been shared to an ArcGIS organization. Mobile workers can use the web map shared for the IPS Setup app to plan, collect, and upload collected survey data, or use it to evaluate indoor positioning performance. After beacons are deployed, you can use the IPS Setup app 1.8 and later to conduct beacon maintenance on-site by scanning the beacon network, capturing the battery value for each detected beacon, and storing the collected maintenance data in the attribute table of the IPS_Beacons layer.
A web map must contain specific map layers and stand-alone tables for use in the IPS Setup app. Before preparing a map for use in IPS Setup, you must create the ArcGIS IPS Information Model and floor plan data in ArcGIS Pro. You can also use the same map for troubleshooting an ArcGIS IPS deployment after making the map IPS-aware.
Required layers
The following layers are required for IPS Setup workflows:
  • Levels—Corresponds to the Levels feature class in the ArcGIS Indoors Information Model and represents the extent of individual floors in the facilities.
  • Facilities—Corresponds to the Facilities feature class in the Indoors model and represents buildings contained within your indoor map.
  • Sites—Corresponds to the Sites feature class in the Indoors model and represents the overall mapped area.
    Caution:
    Sites are optional for ArcGIS Indoors but are mandatory for ArcGIS IPS. This means that the Sites feature class must be created and at least one site feature must be present in the IPS-enabled map.
The following Indoors layers are optional, but it is recommended that you include them for improved functionality and visualization:
  • Details—Corresponds to the Details feature class in the Indoors model and represents walls, doors, and furniture elements.
  • Units—Corresponds to the Units feature class in the Indoors model and represents rooms, hallways, lobbies, and restrooms.
The following IPS layers can be included in the web map:
  • IPS_Beacons—Corresponds to the IPS_Beacons feature class in the ArcGIS IPS model. It represents the locations in your facilities where BLE beacons are installed and maintains information about the beacon network distribution.
    The IPS_Beacons layer is only required for survey-less BLE IPS deployments.
  • IPS_Recordings—Corresponds to the IPS_Recordings feature class in the ArcGIS IPS model and represents IPS survey trajectories across your indoor environment and maintains radio sampling data.
  • IPS_Beacons_Inventory—An optional table that corresponds to the IPS_Beacon_Inventory table in the ArcGIS IPS model. It stores vendor beacon information, and is used by the ArcGIS IPS Setup app 1.9 or later to simplify and standardize beacon deployment.
Layer and table names included in the web map must be exactly as noted above to enable functionality in the ArcGIS IPS Setup app.
Prepare a map for IPS Setup
To create a map and prepare it for use in IPS Setup, complete the following steps:
  1. Open the workspace where you created the ArcGIS IPS model, floor plan data, transitions, and pathways in ArcGIS Pro.
  2. Sign in to your ArcGIS organization if necessary.
  3. On the ribbon, click the Insert tab and click New Map to create a map.
  4. Arrange the layers in the order listed below, and set the name and the layer visibility according to the following table:
    Layer name
    Layer visibility (recommended)
    Details
    On
    Units
    On
    Levels
    On
    Facilities
    On
    Sites
    On
  5. Set the display field in the layer properties to NAME for all map layers.
  6. Optionally, configure the map and the layers as floor-aware.
After completing these steps, continue with the following workflows for additional preparation, as necessary. You can then continue to share the map as a web map to your ArcGIS organization for use in the IPS Setup app.
Prepare the map for beacon deployment
If you are preparing a map for beacon deployment, complete the following steps:
  1. Add the IPS_Beacons feature class to the map.
    Learn more about creating beacon features
  2. Optionally, add the IPS_Beacons_Inventory table to the map.
    Populate the IPS_Beacons_Inventory table with data from the beacon vendor's CSV file to reduce manual data entry later.
Prepare the map for survey or quality data collection
Maps can be evaluated for the accuracy of the positioning data. To prepare a map for survey or quality data collection, complete the following steps:
  1. Add the IPS_Recordings feature class to the map.
  2. Make the map IPS-aware.
    This step is necessary to collect quality recordings, but not required to create survey recordings.
Prepare a map for beacon maintenance
After beacons are deployed, you can use the IPS Setup app 1.8 and later to conduct beacon maintenance. To prepare the map for beacon maintenance, complete the following steps:
Share a map for IPS Setup
Once you prepare a map for use in the ArcGIS IPS Setup app, you can share it as a web map to your ArcGIS organization. Ensure that you configure the following settings before sharing the map:
  • Add the IPS tag in the Tags text box.
    The web map must include the IPS tag to appear in the map list in the IPS Setup app.
  • Under Select a Configuration, click the drop-down arrow and choose one of the following options:
    • Copy all data: Editable
    • Reference Registered Data: Editable
    If you choose the Reference Registered Data: Editable option, ensure that the image layer created when the map is shared is listed last in your web map.
  • If the map includes existing web layers, ensure that the Share with settings for those layers are as inclusive as the Share with setting of the web map. Otherwise, the existing web layers may not be accessible when the web map is opened in Map Viewer and relevant mobile apps. The sharing properties of existing web layers can be viewed and changed in your portal.
Learn more about sharing configurations
Once the web map is successfully shared to your ArcGIS organization, you can open the web map in the IPS Setup app and perform surveys or evaluate positioning accuracy.
