ArcGIS Indoors Information Model
Available with the ArcGIS Indoors Pro or ArcGIS Indoors Maps extension.
The ArcGIS Indoors Information Model supports the management of indoor GIS information necessary to share properly configured web maps and mobile map packages for use with Indoors Viewer, Indoors Space Planner, Indoors Floor Plan Editor, Indoors mobile, and other apps that use floor-aware maps and scenes.
The Indoors model consists of three feature datasets, along with a collection of feature classes and tables that maintain configuration information. You can use the Create Indoors Database tool to apply the Indoors model to an existing workspace. The Indoors workspace created by this tool contains all the fields and tables that are required to support space planning, routing, and workspace reservations in addition to basic floor plan mapping. If you plan to create a floor-aware scene, you can use the Create Indoor 3D Dataset tool to create a feature dataset with multipatch feature classes that conform to the Indoors model.
Alternatively, if you only require support for basic floor plan mapping, you can use the Create Indoor Dataset and Create Indoor Network Dataset tools to create datasets that use a streamlined schema of the Indoors model. These tools do not contain all the fields and tables required for space planning and workspace reservations.
If your Indoors geodatabase was created using a previous version of ArcGIS Pro, you can use the Upgrade Indoors Database tool to update your existing Indoors geodatabase schema to the latest version of the ArcGIS Indoors Information Model schema.
Data can then be loaded into the Indoors model from Revit files using the Import BIM To Indoor Dataset tool, IFC files using the Import IFC To Indoor Dataset tool, or CAD files using the Import CAD To Indoor Dataset tool.
Updates to the Indoors model
The table below describes the changes that were made to the Indoors model in recent software updates:
ArcGIS Pro version
Schema item
Change
3.7
Prelim Network feature dataset
Deprecated PrelimPathways and PrelimTransitions feature classes
To streamline the network creation workflow, the PrelimNetwork dataset has been removed. The feature classes PrelimPathways and Prelim Transitions included in the PrelimNetwork dataset were used by network tools deprecated in the ArcGIS Pro 3.6 release (Generate Indoor Network Dataset, Generate Floor Transitions, Thin Indoor Pathways). The schema is now simplified to only include final network artifacts generated by the Indoors Network tools.
3.6
Organization area management domain
New domain value added: Area Manager added to the DOM_AREA_ROLE domain
This domain value supports organization area managers in the Indoors Space Planner app.
3.5
Units feature class
New field added: ALLOCATIONS
This field supports allocating units to multiple organization areas in Space Planner.
3.4
Occupants feature class
Field aliases updated:
  • Department = Organization Level 1
  • Team = Organization Level 2
These aliases are more generalized and suit a wider variety of use cases.
3.4
New domain value added: Organization added to the DOM_AREA_TYPE domain
This domain value supports organization areas in the Indoors web and mobile apps.
3.4
Organization area management field
New field added: ORG_AREA_ID field added to the Units feature class
This field supports organization areas in the Indoors web and mobile apps.
Review changes to the Indoors model for previous releases.
Feature datasets
The Indoors model includes the following feature datasets:
Name
Indoors
Manages the GIS data that defines indoor spaces for use with Indoors apps. These features are created using the Indoors geoprocessing tools in ArcGIS Pro and are organized by functional levels.
Network
Manages the network artifacts that are created to support routing between indoor spaces. These features are created using the Indoors geoprocessing tools in ArcGIS Pro.
This feature dataset is optional when using the Create Indoors Database tool. It is created using the Create Indoors Database tool or the Create Indoor Network Dataset tool.
Indoor 3D Dataset
Manages the indoor GIS data that defines 3D floor plans for use with floor-aware maps and apps. This feature dataset is created using the Create Indoor 3D Dataset tool in ArcGIS Pro and contains multipatch feature classes organized by functional levels. This feature dataset is optional.
This feature dataset should not be versioned when using an enterprise geodatabase. Versioning is not supported when sharing editable web scene layers.
Tables
The Indoors model includes the following tables:
Name
IndoorsConfig
Describes various settings that can be configured for sharing a location in the ArcGIS Indoors Mobile apps with the option of opening it in an associated Indoors Viewer app.
Areas
Delineates sets of Units that share common space management characteristics such as department, scheduling limits, or cancellation policy. Types of areas include hot desk, hotel, workspace, and organization. This table is populated and managed by Indoors Space Planner.
Area Roles
Provides data model support for configuring reservation managers and area managers in Indoors Space Planner.
Indoors dataset feature classes
The Indoors feature dataset consists of feature classes that are organized into a hierarchy with assumed spatial relationships defined in the following descending order:
  • Units/Details/Events/Occupants/Reservations
  • Sections/Zones/TrackingZones
  • Levels
  • Facilities
  • Sites
The Indoors dataset includes the following feature classes:
Name
Details
Describes linear assets, such as walls, doors, windows, and so on. Details are used to constrain generated network pathways and to support visualization. Details lines must be contained in a Levels feature.
Events
Describes event locations and is used to support the search and explore capabilities, identification, routing, and identification of landmarks in routing. Events are manually loaded from other data sources. The Events feature class can contain both indoor and outdoor information.
Facilities
Describes the footprints of managed buildings.
Levels
Describes the footprint of each level contained in managed facilities. Levels footprints must be contained in a Facilities feature.
Occupants
Contains data about building occupants. This data is used to visualize person assignments on the map and is used for space planning and workspace reservations in the Indoors web and mobile apps.
Reservations
Contains reservation features. This floor-aware, time-aware, editable layer is used to manage workspace reservations and visualize reservations on a map.
Sections
Describes the footprints of nonoverlapping areas of organization in a level, such as wings, and is used for visualization in mapmaking. Sections footprints must be contained in a Levels feature.
Sites
Describes the boundaries of managed sites and is used for visualization in mapmaking.
TrackingZones
Describes geofences for device tracking, areas where device tracking should be enabled. Devices located in a tracking zone will be tracked if they're configured in your environment.
Units
Describes the footprints of nonoverlapping individual functional areas such as workspaces, amenities, retail spaces, elevators and stairways, and so on. Unit footprints must be contained in a Levels feature.
Zones
Describes the footprints of possibly overlapping areas of organization in a level—such as security, functional, managerial, retail zones, and so on—and is used for visualization in mapmaking. Zones footprints must be contained in a Levels feature.
Network feature classes
The Indoors model Network dataset includes the following feature classes:
Name
Landmarks
Describes easily recognizable points that are used as callouts in directions when routing between locations in the Indoors web and mobile apps.
Pathways
Describes the network pathways generated by the Indoors geoprocessing tools in ArcGIS Pro for routing between locations on the same level.
Transitions
Describes the network transitions generated by the Indoors geoprocessing tools in ArcGIS Pro for routing between levels.
Indoor 3D dataset feature classes
The Indoor3D feature dataset consists of multipatch feature classes that represent floor plan information in 3D for visualization purposes.
The feature classes are organized similar to the 2.5D schema, with some additional feature classes for common categories of features. When populating the dataset, you can store multipatch features representing walls, doors, windows, and furniture together in the Details3D feature class or distributed among the Walls3D, Doors3D, Windows3D, and Furniture3D feature classes.
Name
Details3D
Describes any type of detailed architectural features, such as walls, doors, windows, and so on. This feature class is used to support visualization.
Doors3D
Describes different types of doors. This feature class is used to support visualization.
Facilities3D
Describes your managed buildings and other structures. This feature class is used to support visualization.
Furniture3D
Describes different types of furniture, such as desks, chairs, and so on. This feature class is used to support visualization.
Transitions3D
Describes different types of transitions between floors, such as stairways, escalators, and ramps. This feature class is used to support visualization.
Units3D
Describes individual functional areas such as workspaces, amenities, retail spaces, and so on. This feature class is used to support visualization.
Walls3D
Describes different types of walls. This feature class is used to support visualization.
Windows3D
Describes different types of windows. This feature class is used to support visualization.
Indoors model feature class fields
Click a link below to go to a feature class fields table.
| Details | Events | Facilities | Levels | Occupants | Reservations | Sections | Sites | TrackingZones | Units | Zones |
All fields that have an Is nullable value of True are optional.
Details
The Details feature class includes the following fields:
Field name
Type
Is nullable
DETAIL_ID
Text
False
Defines a unique ID for the feature. This value must be unique in the table. The uniqueness of this field is not enforced by the geodatabase.
HEIGHT_RELATIVE
Double
True
Defines the height of the feature relative to the bottom of the floor. Define height in meters, for example, Level 1 = 4.25 m, Level 2 = 4.25 m, and so on.
This field is not populated by default when using the import tools, but you can populate it manually.
LEVEL_ID
Text
False
Records the unique ID of the feature’s associated level. This ID is used to identify the feature’s associated level feature in floor-aware maps. A feature can only be related to a single level using the Level ID field.
USE_TYPE
Text
True
Distinguishes feature types used in tool processing and supports differences in symbology for mapmaking.
Events
The Events feature class includes the following fields:
Field name
Type
Is nullable
DATE_END
Date
False
Defines the end date for the event in coordinated universal time (UTC).
DATE_START
Date
False
Defines the start date for the event in coordinated universal time (UTC).
DESCRIPTION
Text
True
Provides a description of the feature for use in turn-by-turn directions.
EVENT_ID
Text
False
IMAGE_URL
Text
True
Provides a URL for displaying a single associated image in pop-ups in the Indoors web and mobile apps.
LEVEL_ID
Text
True
NAME
Text
False
Defines the name of the feature. In most cases, the NAME field of a feature is the most commonly used field for naming features.
NAME_LONG
Text
True
Defines a long name for a feature. The long name is used to support descriptive capabilities in the Indoors web and mobile apps.
NAME_SUBTITLE
Text
True
Defines a subtitle for a feature. A subtitle is required to support some capabilities in the Indoors Viewer app.
UNIT_ID
Text
True
Records the unique ID of the feature’s associated unit and can be used to identify the feature’s associated unit feature. A feature can only be related to a single unit using the Unit ID field.
USE_TYPE
Text
False
Facilities
The Facilities feature class includes the following fields:
Field name
Type
Is nullable
FACILITY_ID
Text
False
HEIGHT_RELATIVE
Double
True
Defines the height of the facility compared to the bottom of the ground floor of the facility. Define height in meters.
This field is used when creating a 3D scene.
LEVELS_ABOVE_GROUND
Long
True
Defines the total number of floors in a facility that are above ground.
NAME
Text
False
NAME_LONG
Text
True
SITE_ID
Text
True
Records the unique ID of the feature’s associated site and can be used to identify the feature’s associated site feature in floor-aware maps. A feature can only be related to a single site using the Site ID field.
Levels
The Levels feature class includes the following fields:
Field name
Type
Is nullable
AREA_GROSS
Double
True
Records the total gross area of a feature.
FACILITY_ID
Text
False
Records the unique ID of the feature’s associated facility and is used to identify the feature’s associated facility feature in floor-aware maps. A feature can only be related to a single facility using the Facility ID field.
HEIGHT_RELATIVE
Double
True
LEVEL_ID
Text
False
LEVEL_NUMBER
Long
False
Records the facility-specific level number.
NAME
Text
False
NAME_SHORT
Text
False
Defines a short name for a feature. The short name is used to support the floor filter. This field must be populated.
VERTICAL_ORDER
Long
False
Uses a zero (0)-based ordering system to define the floor order, with the ground level of each facility represented as zero. Positive values represent floors above ground, and negative values represent floors below ground. Vertical order values must be continuous and cannot skip a value in the sequence.
Occupants
The Occupants feature class includes the following fields:
Field name
Type
Is nullable
AREA_ID
Text
True
The unique ID of the workspace area to which the occupant is assigned.
CONTACT_EXTENSION
Text
True
The phone extension that must be added to the contact phone number to reach the occupant directly.
CONTACT_PHONE
Text
True
The phone number where the occupant can be reached directly.
EMAIL
Text
False
The occupant's unique email address. Two occupants can have the same known name, but their email addresses must be different.
JOB_TITLE
Text
True
The occupant's job title.
KNOWNAS
Text
False
The occupant's name, including first and last name.
LEVEL_ID
Text
True
The unique ID of the level on which the occupant's assignment is located.
ORG_LEVEL_1
Text
True
The first organization level to which the occupant is assigned, such as a department.
ORG_LEVEL_2
Text
True
The second organization level to which the occupant is assigned, such as a team.
SITE_ID
Text
True
The unique ID of the site to which the occupant is assigned.
START_DATE
Date
True
The occupant's start date.
UNIT_ID
Text
True
The unique ID of the unit to which the occupant is assigned.
Reservations
The Reservations feature class includes the following fields:
Field name
Type
Is nullable
ALL_DAY
Long
False
Indicates whether a reservation is an all-day event. This field uses a domain to define the following allowed values:
  • 0 = Not all day
  • 1 = All day
CHECK_IN_TIME
Date
True
The date and time (in UTC) that the people for whom the reservation was made checked in.
CHECK_OUT_TIME
Date
True
The date and time (in UTC) that the people for whom the reservation was made checked out.
DESCRIPTION
Text
True
A description of the reservation or meeting.
END_TIME
Date
False
The scheduled end date and time of the reservation (in UTC).
LEVEL_ID
Text
True
The unique ID for the level on which the feature is located.
RESERVED_BY_FULL_NAME
Text
True
The full name of the reservation manager who created a reservation for someone else.
RESERVED_BY_USERNAME
Text
True
The ArcGIS organization username of the reservation manager who created a reservation for someone else.
RECURRENCE_CONFIG
Text
True
Populated and managed by Indoors Viewer and Indoors mobile to support recurring bookings for office hotels.
RESERVED_FOR_FULL_NAME
Text
False
The full name of the person for whom the reservation is held. This is useful for display and labeling.
RESERVED_FOR_USERNAME
Text
False
The ArcGIS organization username of the person for whom the reservation is held.
RECURRENCE_ID
Text
True
A GUID value populated and managed by Indoors Viewer and Indoors Mobile to support recurring bookings for office hotels. This value can be shared by multiple reservations to indicate they belong to the same recurrence.
START_TIME
Date
False
The scheduled start date and time of the reservation (in UTC).
STATE
Long
False
The current state of the reservation is automatically managed by the Viewer app as users create bookings. This field uses a domain to define the following allowed values:
  • 0 = Pending—This status is temporarily used by the app to prevent double bookings if multiple users submit a booking request for the same space and time within a few seconds.
  • 1 = Reserved—The space has been successfully reserved.
  • 3 = Canceled—The reservation has been canceled.
  • 4 = Checked in—The user has checked in to the reserved space.
  • 5 = Checked out—The user has checked out of the reserved space.
TITLE
Text
True
Describes the reservation or meeting.
UNIT_ID
Text
False
The unit ID of the reserved unit.
UNIT_NAME
Text
True
The name of the reserved unit. This is useful for display and labeling.
Sections
The Sections feature class includes the following fields:
Field name
Type
Is nullable
AREA_GROSS
Double
True
HEIGHT_RELATIVE
Double
True
LEVEL_ID
Text
False
NAME
Text
True
NAME_LONG
Text
True
SECTION_ID
Text
False
Sites
The Sites feature class includes the following fields:
Field name
Type
Is nullable
NAME
Text
False
NAME_LONG
Text
True
SITE_ID
Text
False
TrackingZones
The TrackingZones feature class includes the following fields:
Field name
Type
Is nullable
DESCRIPTION
Text
True
LEVEL_ID
Text
True
TRACK_TYPE
Long
True
Defines the tracking rule for a feature. It uses a domain to define the following allowed values:
  • 1 = Track
  • 2 = Do Not Track
TRACKING_ZONE_ID
Text
True
Units
The Units feature class includes the following fields:
Field name
Type
Is nullable
ALLOCATIONS
Text
True
The organization areas to which the unit has been allocated. This field is used if a unit is allocated to multiple organization areas and is updated by the Space Planner app.
AREA_GROSS
Double
True
AREA_ID
Text
True
Records an ID string referencing a Space Planner area.
ASSIGNMENT_TYPE
Text
True
Describes the type of space planning use assigned to the unit. It's used by the Indoors Space Planner app. This field uses a domain to define the following allowed values:
  • hotdesk = Hot Desk
  • hotel = Hotel
  • office = Office
  • meeting room = Meeting Room
  • none = None (Default)
  • not assignable = Not Assignable
CAPACITY
Long
True
Records the total capacity of a feature.
HEIGHT_RELATIVE
Double
True
LEVEL_ID
Text
False
NAME
Text
False
NAME_LONG
Text
True
ORG_AREA_ID
Text
True
The organization area to which the unit is assigned.
RESERVATION_METHOD
Long
True
Defines whether a unit is reservable as a meeting room. This field uses a domain to define the following allowed values:
  • 0 = Not reservable
  • 1 = Reservable
This field is only applicable for meeting rooms when using the Reservations layer and is not used for reservations with Microsoft 365. This field is also not used for office hotels or hot desks that are automatically reservable.
SCHEDULE_EMAIL
Text
True
Records the email address used to submit reservation requests for the item.
UNIT_ID
Text
False
USE_TYPE
Text
True
Zones
The Zones feature class includes the following fields:
Field name
Type
Is nullable
AREA_GROSS
Double
True
HEIGHT_RELATIVE
Double
True
LEVEL_ID
Text
False
NAME
Text
True
NAME_LONG
Text
True
ZONE_ID
Text
False
Network feature class fields
The following subsections describe the landmarks, pathways, and transitions feature class fields.
Landmarks
The Landmarks feature class includes the following fields:
Field name
Type
Is nullable
DESCRIPTION
Text
True
LEVEL_ID
Text
True
VERTICAL_ORDER
Long
False
Pathways
The Pathways feature class includes the following fields:
Field name
Type
Is nullable
DELAY
Long
True
Defines the elevator delay in the network for accurate routing time.
FACILITY_ID
Text
True
FACILITY_NAME
Text
True
Records the name of the feature’s associated facility. The facility name is used in routing to determine when a route leaves and enters a facility and triggers additional text in the turn-by-turn directions.
LENGTH_3D
Double
False
Describes the calculated length of the feature in 3D that is used to determine path cost when routing.
LEVEL_ID
Text
True
LEVEL_NAME_FROM
Text
False
Describes the short name of the level on which the feature originates as defined in the indoor feature dataset.
LEVEL_NAME_TO
Text
False
Describes the short name of the level on which the feature terminates as defined in the indoor feature dataset.
PATHWAY_RANK
Long
True
Defines the rank preference of one feature versus another for routing. The following domain is used to define allowed values:
  • 1 = Primary
  • 2 = Secondary
  • 3 = Tertiary
PATHWAY_TYPE
Long
True
Describes the use type of the feature and is used to determine cost and restrictions when routing. The following domain is used to define allowed values:
  • 1 = Hallway/Sidewalk
  • 2 = Stairs/Curb
  • 3 = Ramp/Curb Ramp
  • 4 = Elevator/Wheelchair Lift
  • 5 = Escalator
  • 6 = Moving Walkway
TRAVEL_DIRECTION
Long
True
Defines the direction of travel for a feature and is used to support restrictions when routing. The following domain is used to define allowed values:
  • 1 = Both Directions Allowed
  • 2 = From-To Allowed
  • 3 = To-From Allowed
VERTICAL_ORDER
Long
False
Transitions
The Transitions feature class includes the following fields:
Field name
Type
Is nullable
FACILITY_ID
Text
False
FACILITY_NAME
Text
False
HEIGHT_FROM
Double
True
Defines the starting height of the feature.
HEIGHT_TO
Double
True
Defines the ending height of the feature.
LENGTH_3D
Double
False
LEVEL_NAME_FROM
Text
False
LEVEL_NAME_TO
Text
False
TRANSITION_RANK
Long
True
  • 1 = Primary
  • 2 = Secondary
  • 3 = Tertiary
TRANSITION_TYPE
Long
False
  • 2 = Stairs/Curb
  • 5 = Escalator
TRAVEL_DIRECTION
Long
True
VERTICAL_ORDER_FROM
Long
False
Defines the order of display and reference to floors in the IPS of the level as defined in the indoor feature dataset on which the feature originates.
It uses a zero (0)-based ordering system to define the floor order, with the ground level of each facility represented as zero. Subsequent positive values represent floors above ground, and negative values represent floors below ground. Vertical Order From values must be continuous and cannot skip a value in the sequence.
VERTICAL_ORDER_TO
Long
False
Defines the order of display and reference to floors in the IPS of the level as defined in the indoor feature dataset on which the feature terminates.
It uses a zero (0)-based ordering system to define the floor order, with the ground level of each facility represented as zero. Subsequent positive values represent floors above ground, and negative values represent floors below ground. Vertical Order To values must be continuous and cannot skip a value in the sequence.
Table fields
The following subsections describe Areas, Area roles, and IndoorsConfig table fields.
Areas
The Areas table includes the following fields:
Field name
Type
Is nullable
AREA_ID
Text
False
Records an ID string referencing an area specified in the Space Planner app.
AREA_TYPE
Text
False
Describes the type of space planning use assigned to the area. It is used by the Indoors Space Planner app.
This field uses a domain to define the following supported values:
  • Hot Desk
  • Hotel
  • Organization
  • Workspace
AREA_NAME
Text
False
Describes the name of an Indoors Space Planner area.
CONFIG
Text
True
Populated and managed by the Indoors Space Planner app. This field is used by the Indoors Viewer and Indoors Mobile apps to manage configuration information such as cancellation policies and scheduling limits.
RESTRICTED
Long
True
Describes whether an area can be booked by anyone or only booked by occupants who are assigned to the area. This field uses a domain to define the following allowed values:
  • 0 = Unrestricted
  • 1 = Restrict bookings to assigned occupants. This is the default.
Features with a null field value are treated as unrestricted in Indoors Viewer.
Area Roles
The Area Roles table includes the following fields:
Field name
Type
Is nullable
AREA_ID
Text
False
USERNAME
Text
True
The reservation manager's associated username in the ArcGIS organization.
EMAIL
Text
False
The reservation manager's associated email address in the ArcGIS organization.
ROLE
Long
False
This field uses a domain value of 1 to define a reservation manager or a value of 2 to define an area manager.
IndoorsConfig
The IndoorsConfig table includes the following fields:
Field name
Type
Is nullable
CONFIG_KEY
Text
True
Describes the configurable parameter as required by Indoors.
CONFIG_VALUE
Text
True
Records the configurable entry as defined by the implementation requirements.
This field is required for configurable items in an implementation.
Indoor 3D dataset feature class fields
| Details3D | Doors3D | Facilities3D | Furniture3D | Transitions3D | Units3D | Walls3D | Windows3D |
Details3D
The Details3D feature class includes the following fields:
Field name
Type
Is nullable
DETAIL_ID
Text
False
LEVEL_ID
Text
True
Records the unique ID of the feature's associated level and can be used to identify the feature's associated 2D level feature in floor-aware scenes. A feature can only be related to a single level using this field.
SOURCE_ID
Text
True
Records the stable unique ID of the source feature, if available. For features sourced from Revit data, this field contains the value of the source element's UniqueID property. For features sourced from CAD data, this field will be Null.
USE_TYPE
Text
True
Distinguishes feature types to support differences in symbology for visualization.
Doors3D
The Doors3D feature class includes the following fields:
Field name
Type
Is nullable
DOOR_ID
Text
False
DOOR_TYPE
Text
True
LEVEL_ID
Text
True
Records the unique ID of the feature's associated level and can be used to identify the feature's associated 3D level feature in floor-aware scenes. A feature can only be related to a single level using this field.
SOURCE_ID
Text
True
Facilities3D
The Facilities3D feature class includes the following fields:
Field name
Type
Is nullable
FACILITY_ID
Text
False
NAME
Text
False
NAME_LONG
Text
True
SITE_ID
Text
True
Records the unique ID of the feature's associated site and can be used to identify the feature's associated 3D site feature in floor-aware scenes. A feature can only be related to a single site using this field.
Furniture3D
The Furniture3D feature class includes the following fields:
Field name
Type
Is nullable
FURNITURE_ID
Text
False
FURNITURE_TYPE
Text
True
LEVEL_ID
Text
True
SOURCE_ID
Text
True
Transitions3D
The Transitions3D feature class includes the following fields:
Field name
Type
Is nullable
LEVEL_ID
Text
True
SOURCE_ID
Text
True
TRANSITION_ID
Text
False
Records the unique ID of the feature. This value must be unique in the table. The uniqueness of this field is not enforced by the geodatabase.
TRANSITION_TYPE
Long
True
Units3D
The Units3D feature class includes the following fields:
Field name
Type
Is nullable
AREA_GROSS
Double
True
LEVEL_ID
Text
True
NAME
Text
False
NAME_LONG
Text
True
SOURCE_ID
Text
True
UNIT_ID
Text
False
USE_TYPE
Text
True
Walls3D
The Walls3D feature class includes the following fields:
Field name
Type
Is nullable
LEVEL_ID
Text
True
MATERIAL_TYPE
Text
True
SOURCE_ID
Text
True
WALL_ID
Text
False
WALL_TYPE
Text
True
Windows3D
The Windows3D feature class includes the following fields:
Field name
Type
Is nullable
LEVEL_ID
Text
True
SOURCE_ID
Text
True
WINDOW_ID
Text
False
WINDOW_TYPE
Text
True
Distinguishes features to support differences in symbology for visualization.
Indoors model coded value domains
The Indoors model schema includes coded value domains applied to specific fields to enable functionality in Indoors apps. For example, there are domains to prioritize paths in an indoor routable network during navigation, and domains that determine which rooms are assigned to office hotels and are available for booking in Indoors Viewer and Indoors Mobile.
Some of these coded value domains are managed by the user in ArcGIS Pro, while others are managed by Indoors apps.
The following table describes the Indoors model coded value domains:
Domain name / Coded Values
Feature class / Table: Field
DOM_ALL_DAY
  • 0 = Not all day
  • 1 = All day
Reservations: ALL_DAY
Indicates whether an all-day booking has been made for a unit.
This is managed by Indoors Viewer.
DOM_AREA_ROLE
  • 1 = Reservation Manager
  • 2 = Area Manager
AreaRoles: ROLE
Indicates if an occupant is a reservation manager or area manager. Reservation managers can book or cancel bookings for others using the Reservations layer in Indoors Viewer and Indoors Mobile. Area managers can allocate units to organization areas in Indoors Space Planner.
This is managed by Space Planner.
DOM_AREA_TYPE
  • hotel = Hotel
  • workspace = Workspace
  • organization = Organization
Areas: AREA_TYPE
Defines office hotel, hot desk, workspace, and organization areas.
DOM_ASSIGNMENT_TYPE
  • hotel = Hotel
  • none = None
  • office = Office
Units: ASSIGNMENT_TYPE
Defines the assignment type of a unit as follows:
  • None—The unit is not assigned to an occupant, hotel, or hot desk area but can be assigned using Space Planner. Units are assigned a value of None by default when created with the Indoors tools.
  • Not Assignable—The unit cannot be booked or assigned in Indoors apps. You can assign spaces such as hallways or restrooms as Not Assignable when configuring data in the Indoors workspace.
  • Office—The assignment type is updated to Office when an occupant is assigned to a unit using Space Planner or the Update Occupant Features tool.
  • Hotel—The assignment type is set to Hotel when a unit is defined as an office hotel in a workspace area in Space Planner.
  • Hot Desk—The assignment type is set to Hot Desk when a unit is defined as a hot desk within a workspace area in Space Planner.
  • Meeting Room—The assignment type is set to Meeting Room when a unit is defined as a meeting room in a workspace area in Space Planner.
DOM_EQUIPMENT
  • 0 = No
  • 1 = Yes
Units: Defined by user
Defines fields with available equipment types. Use this domain when the equipment type applies to both meeting rooms and office hotels.
Fields that include this domain will appear as options in the equipment filter in Indoors Viewer and Indoors Mobile.
This is managed by the user. Assign this domain to equipment fields added to the Units layer.
DOM_EQUIPMENT_HOTEL
  • 0 = No
  • 1 = Yes
Defines fields with available equipment types. Use this domain when the equipment type applies to office hotels only.
DOM_EQUIPMENT_MEETING
  • 0 = No
  • 1 = Yes
Defines fields with available equipment types. Use this domain when the equipment type applies to meeting rooms only.
DOM_RESERVATION_METHOD
  • 1 = Reservable
Units: RESERVATION_METHOD
Defines whether the unit is a meeting room and can be booked for reservations using Indoors Viewer and Indoors Mobile.
This is managed by the user in ArcGIS Pro when configuring meeting rooms with the Reservations layer.
DOM_RESERVATION_STATE
  • 0 = Pending
  • 1 = Reserved
  • 3 = Canceled
  • 4 = Checked in
  • 5 = Checked out
Reservations: STATE
Describes the current booking status of a unit in Indoors Viewer and Indoors Mobile.
This is managed by Indoors Viewer and Indoors Mobile.
DOM_RESTRICTED
  • 0 = Unrestricted
Areas: RESTRICTED
Defines whether an office hotel is restricted to bookings by assigned occupants. Occupants must be assigned to the restricted hotel in Space Planner before they can book it in Indoors Viewer and Indoors Mobile.
DOM_TRACK_TYPE
  • 1 = Track
  • 2 = Do Not Track
TrackingZones: TRACK_TYPE
Defines the rule for device tracking within a specific area.
This is managed by the user in ArcGIS Pro when configuring tracking zones.
