Enable Indoor Positioning (Indoor Positioning Tools)
Summary
Creates the feature classes and table necessary for storing ArcGIS IPS data in an existing geodatabase.
Legacy:
This tool is deprecated and will be removed at the next release of ArcGIS Pro. Use the Create IPS Data Model tool for enhanced functionality and performance.
Usage
The Input Workspace parameter value must be an existing geodatabase. It can be a file or enterprise geodatabase.
When using an enterprise geodatabase, the connection file must connect directly to the database as the database owner.
You can use the Output Beacons Feature Class value to update the beacon information for an existing beacon deployment and to plan new beacon deployments. Information about deployed beacons can be updated using the ArcGIS Field Maps mobile app, or by editing the Beacons feature class in ArcGIS Pro or Map Viewer.
Parameters
| Label | Explanation | Data type |
Input Workspace |
The geodatabase where the ArcGIS IPS table and feature classes will be created. It can be a file or enterprise geodatabase. |
Workspace |
Derived output
Output IPS Recordings Feature Class |
The output IPS Recordings feature class that is created. |
Feature Class |
Output IPS Positioning Table |
The output IPS Positioning table that is created. |
Table |
Updated input workspace |
The file or enterprise geodatabase in which the ArcGIS IPS table and feature classes are created. |
Workspace |
Output Beacons Feature Class |
The output IPS Beacons feature class that is created. |
Feature Class |
Environments
Licensing information
- Basic: No
- Standard: Requires ArcGIS IPS
- Advanced: Requires ArcGIS IPS
