Copy Knowledge Graph Types (Knowledge Graph Tools)
Summary
Copies the data model and data from one knowledge graph to another.
Usage
  • Use this tool to copy entity and relationship types from one knowledge graph to another.
  • To avoid schema conflicts, the types selected to copy should not exist in the target knowledge graph.
  • If the entity or relationship type exists in both knowledge graphs, the types in the target knowledge graph should not have entities or relationships and all settings must match exactly.
  • Copying provenance records will not result in a schema conflict.
  • System managed properties with custom names, such as custom document names in both the source and target knowledge graph will use the properties of the target knowledge graph. Custom properties in the source knowledge graph will not be copied.
  • The target knowledge graph must already exist. If the input and target knowledge graphs are on different portals, set your active portal to the portal with the target knowledge graph.
  • When an entity or relationship type in the source knowledge graph has additional properties for types in the target knowledge graph, the additional properties will be added to the existing types in the target knowledge graph.
  • The Include provenance parameter is only available when provenance is enabled in both the input and target knowledge graphs.
Parameters
Label Explanation Data type
Knowledge Graph
The knowledge graph from which the data model and data will be copied.
Workspace
Target Knowledge Graph
The knowledge graph that will be updated.
Workspace
Entity types
(Optional)
The entity types and entities that will be copied to the target knowledge graph.
String
Relationship types
(Optional)
The relationship types and relationships that will be copied to the target knowledge graph.
String
Include provenance
(Optional)
Specifies whether provenance records will be copied to the target knowledge graph.
  • Checked—Provenance records will be copied to the target knowledge graph.
  • Unchecked—Provenance records will not be copied to the target knowledge graph.
Boolean
Derived output
Updated Knowledge graph
The updated knowledge graph.
Workspace
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
