Export Knowledge Graph (Knowledge Graph Tools)
Summary
Creates a service definition file of a knowledge graph.
Usage
  • This tool creates a service definition file based on the input knowledge graph service.
  • The output service definition file will contain the data model and all data from the knowledge graph service.
  • Use this tool to create a backup of your knowledge graph service or share it within your organization. You can schedule the tool to run at regular intervals to keep your knowledge graph securely backed up and up to date.
  • The Input Knowledge Graph parameter value must be the url of the knowledge graph service.
  • A knowledge graph service definition file can be shared to ArcGIS Enterprise 12.0 or later.
    Learn more about sharing a knowledge graph service definition
Parameters
Label Explanation Data type
The knowledge graph that will be used to create a service definition.
Knowledge Graph
Output Service Definition
The output service definition file.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
