Upload Service Definition (Server Tools)
Summary
Uploads and shares a web layer, locator, web tool, service, or knowledge graph to ArcGIS Online, ArcGIS Enterprise, or ArcGIS Server.
Usage
This tool uploads and shares a web layer, locator, web tool, service, or knowledge graph based on the input service definition.
This tool does not upload and share service definition draft files (
.sddraft). If you have a service definition draft, you can convert it to a staged service definition using the Stage Service tool.Web tools can only be shared to ArcGIS Enterprise. Geoprocessing services can only be published to ArcGIS Server.
Locators can only be shared to ArcGIS Enterprise. Geocode services can only be published to ArcGIS Server.
Knowledge graphs can only be shared to ArcGIS Enterprise 12.0 or later.
You can specify item IDs when sharing the following to the corresponding ArcGIS Enterprise versions:
Web feature layer that copies all data—ArcGIS Enterprise 10.8.1 or later
Web tile layer—ArcGIS Enterprise 10.8.1 or later
Map image layer—ArcGIS Enterprise 11.2 or later
Web feature layer that references registered data—ArcGIS Enterprise 11.2 or later
OGC feature layer—ArcGIS Enterprise 11.2 or later
WMS service layer—ArcGIS Enterprise 11.2 or later
WFS service layer—ArcGIS Enterprise 11.2 or later
Knowledge graphs—ArcGIS Enterprise 12.0 or later
Parameters
| Label | Explanation | Data type |
Service Definition |
The service definition file ( |
File |
Server |
The server type. The following server types are supported:
ServerConnection |
Service Name (Optional) |
The service name that will override the current service name specified in the service definition. |
String |
Cluster (Optional) |
The cluster name that will override the current cluster to which the service has been assigned. You must choose from clusters on the specified server. Legacy:Clusters are deprecated at ArcGIS Enterprise 10.5.1. This parameter will be ignored for servers that do not support multiple clusters. |
String |
Folder Type (Optional) |
Specifies the folder type that will be used to determine the source for the folder. The default is a folder from the service definition. You can also get a list of existing folders on the specified online server, or you can specify that a new folder be created once you share the web layer, service, or knowledge graph.
String |
Folder (Optional) |
The folder that will be used for the web layer, service, or knowledge graph. If no folder is provided, the folder specified in the service definition will be used. If you specified New for Folder Type, use this parameter to provide a folder name. If you specified Existing for Folder Type, you can choose from the existing folders on the server. |
String |
Start service immediately (Optional) |
Specifies whether the service will be started after sharing.
Boolean |
Override service definition sharing properties (Optional) |
Specifies whether the sharing properties set in the service definition will be overridden. These properties define if, and how, you are sharing the web layer, web tool, or knowledge graph with ArcGIS Online or ArcGIS Enterprise. You must be signed in to ArcGIS Online or ArcGIS Enterprise to override sharing properties. This parameter is not honored when sharing to ArcGIS Server.
Boolean |
Share on ArcGIS Online (Optional) |
Specifies whether the web layer, web tool, or knowledge graph will be shared. All shared web layers, web tools, or knowledge graphs are available through My Content. Even if you only want to share with a specific group in your organization, the web layer, web tool, or knowledge graph will also be shared through My Content. You must be signed in to a portal to override sharing properties. This parameter is not honored when sharing to ArcGIS Server.
Boolean |
Share With Everyone (Public) (Optional) |
Specifies whether the web layer or web tool will be available to the public. You must be signed in to ArcGIS Online or ArcGIS Enterprise to override sharing properties. This parameter is not honored when sharing to ArcGIS Server. This parameter is not supported when sharing a knowledge graph.
Boolean |
Share With Your Organization (Optional) |
Specifies whether the web layer, web tool, or knowledge graph will be shared with your organization. You must be signed in to ArcGIS Online or ArcGIS Enterprise to override sharing properties. This parameter is not honored when sharing to ArcGIS Server.
Boolean |
Share With These Groups (Optional) |
Specifies whether the web layer, web tool, or knowledge graph will be shared with specified groups in your organization.
You must be signed in to ArcGIS Online or ArcGIS Enterprise to override sharing properties. This parameter is not honored when sharing to ArcGIS Server. |
String |
Output Item IDs (Optional) |
Specifies the item IDs of the output web layers or knowledge graph staged in the input service definition. An item ID can be specified for each item. The ID must be available and contain 32 alphanumeric values ranging from the letters a to f and numbers 0 to 9. If no ID is provided, an item ID will be automatically created. Item IDs can be specified for the following:
This parameter is not available if the service definition is set to overwrite an existing service or if an ArcGIS Server connection or URL to ArcGIS Server is provided. Value table columns:
Value Table |
Derived output
SOAP Service URL |
The SOAP URL of a service published to the server. |
String |
REST Service URL |
The REST URL of a service published to the server. |
String |
Hosted Map Service Item ID |
The Item ID of the map image layer shared to the portal. |
String |
Hosted Feature Service Item ID |
The Item ID of the hosted feature service layer shared to the portal. |
String |
Cached Service |
An image service or a map service with caching enabled. |
Image Service; Map Server |
Feature Service URL |
The REST URL of a hosted feature layer shared to the portal. |
String |
Map Service URL |
The REST URL of a map image layer shared to the portal. |
String |
Layer ID |
The published layers and their respective IDs in the format Layer1|ID1;Layer2|ID2; and so on. |
String |
Service URL |
The published stand-alone tables and their respective IDs in the format Table1|ID1;Table2|ID2; and so on. |
String |
Hosted Vector Tile Service Item ID |
The Item ID of the vector tile service. |
String |
Vector Tile Service URL |
The REST URL of the vector tile service. |
String |
Item ID |
The Item IDs of the web items shared to the portal. An Item ID will include one of the following strings:
Value Table |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
