An overview of the Publishing toolset
The Publishing toolset contains tools to stage, upload, and share web layers and services.
Tool
Replace Web Layer
Replaces the content of a web layer in a portal with the content of another web layer.
Stage Service
Stages a service definition. A staged service definition file (.sd) contains all the necessary information to share a web layer, locator, web tool, or service.
Upload Service Definition
Uploads and shares a web layer, locator, web tool, service, or knowledge graph to ArcGIS Online, ArcGIS Enterprise, or ArcGIS Server.
Publishing toolset
Automate the sharing of web layers and services
You can automate sharing and updating web layers and services with Python by using a combination of ArcPy functions and geoprocessing tools in the Publishing toolset. The workflow begins with a map in a project or a raster dataset that you want to share.
  • First, create a service definition draft using the arcpy.sharing module or the CreateGeocodeSDDraft ArcPy functions.
  • Next, stage the service definition. Staging takes the service definition draft and consolidates all the information needed to share the web layer or service into a complete service definition. Use the Stage Service tool to stage the service definition.
  • Finally, use the Upload Service Definition tool to upload the service definition and publish the web layer or service.
You must sign in to ArcGIS Online, ArcGIS Enterprise, or ArcGIS Server to share your web layer or service with an account that has privileges to create content and publish.
