Configure Address Feature Classes (Linear Referencing Tools)
Summary
Configures the Address Range and Site Address Point feature classes from the Address Data Management solution for use with a linear referencing system (LRS) and the ArcGIS Linear Referencing extension.
Usage
You must provide an LRS centerline feature class or an LRS line event that includes addressing information for the Input Address Range Feature Layer parameter.
Learn more about the LRS data model and the Address Data Management solution in ArcGIS Enterprise.
The Left From Address Field, Left To Address Field, Right From Address Field, and Right To Address Field parameter values must be short or long field types.
The Address Range Road Name Field parameter value must be a text field type.
You must provide a point feature class for the Input Site Address Feature Layer parameter.
The Address Number Field parameter value must be a short, long, or text field type.
The Site Address Road Name parameter value must be a text field type.
The feature classes that you use for the Input Address Range Feature Layer and Input Site Address Feature Layer parameter values must be in the same feature dataset as the LRS layers.
This tool supports data from a file geodatabase or an enterprise geodatabase (branch versioned or traditional versioned connection).
This tool does not support data from a feature service.
Parameters
| Label | Explanation | Data type |
Input Address Range Feature Layer |
The input LRS centerline or LRS line event feature class that will be configured as the Address Range feature class. |
Feature Layer |
Left From Address Field |
The field in the Address Range feature class that contains information for the first address on the left side of a roadway. |
Field |
Left To Address Field |
The field in the Address Range feature class that contains information for the last address on the left side of a roadway. |
Field |
Right From Address Field |
The field in the Address Range feature class that contains information for the first address on the right side of a roadway. |
Field |
Right To Address Field |
The field in the Address Range feature class that contains information for the last address on the right side of a roadway. |
Field |
Input Site Address Features |
The input point feature class that is the Site Address Point feature class from the Address Data Management solution. |
Feature Layer |
Address Number Field |
The field in the Site Address Point feature class that contains information for the site address number. |
Field |
Address Range Road Name Field |
The field in the Address Range feature class that contains information for the name of a roadway. |
Field |
Site Address Road Name Field |
The field in the Site Address Point feature class that contains information for the name of a roadway. |
Field |
Derived output
Output Address Range Features |
The updated Address Range feature class. |
Feature Layer |
Output Site Address Features |
The updated Site Address Point feature class. |
Feature Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
