An overview of the Configuration toolset
The Configuration toolset contains tools for creating or modifying an LRS, an LRS event, an LRS intersection, and an LRS Network. The toolset also includes tools to configure feature classes from the Address Data Management solution or a utility network for use with an LRS.
Tool |
Description |
Configures the Address Range and Site Address Point feature classes from the Address Data Management solution for use with a linear referencing system (LRS). |
Configures the ArcGIS Utility Network Pipeline Line, Pipeline Device, and Pipeline Junction feature classes for use with a linear referencing system (LRS). |
Removes a linear referencing system (LRS) entity from an input geodatabase workspace. |
Toolset |
Description |
The LRS toolset contains tools to create or modify an LRS. |
The LRS Event toolset contains tools to create or modify an LRS event. |
The LRS Intersection toolset contains tools to create or modify an LRS intersection. |
The LRS Network toolset contains tools to create or modify an LRS Network. |
