Configure Utility Network Feature Classes (Linear Referencing Tools)
Summary
Configures the ArcGIS Utility Network Pipeline Line, Pipeline Device, and Pipeline Junction feature classes for use with a linear referencing system (LRS).
Usage
  • The Utility Network Pipeline Line feature class serves as the centerline feature class in the LRS.
    Learn more about the LRS data model
  • This tool supports data from a file geodatabase or an enterprise geodatabase (branch versioned connection).
    Learn more about versioning in ArcGIS Pro
  • This tool does not support data from a feature service.
  • After running this tool, the following are supported:
    • You can update the route ID and measure fields on the utility network feature classes as needed using the Update Measures From LRS tool.
    • You can use the utility network feature classes as inputs to the Overlay Events tool for dynamic segmentation.
Parameters
Label Explanation Data type
Utility Network Line Layer
The input Utility Network Pipeline Line feature class that will serve as the LRS centerline feature class.
Feature Layer
Line Route ID Field
The field in the Pipeline Line feature class that will be mapped as the route ID field in the LRS Network.
The data type and length of the field must match those of the corresponding field in the LRS centerline sequence table.
Field
Line From Measure Field
The start measure field of the Pipeline Line feature class.
Field
Line To Measure Field
The end measure field of the Pipeline Line feature class.
Field
Utility Network Devices Layer
The input Utility Network Pipeline Device feature class.
Feature Layer
Devices Route ID Field
The field in the Pipeline Device feature class that contains the route ID attribute.
Field
Devices Measure Field
The field in the Pipeline Device feature class that contains the measure value for devices.
Field
Utility Network Junctions Layer
The input Utility Network Pipeline Junction feature class.
Feature Layer
Junctions Route ID Field
The field in the Pipeline Junction feature class that contains the route ID attribute.
Field
Junctions Measure Field
The field in the Pipeline Junction feature class that contains the measure value for junctions.
Field
Derived output
Output Line Feature Class
The updated Utility Network Pipeline Line feature class.
Feature Layer
Output Devices Feature Class
The updated Utility Network Pipeline Device feature class.
Feature Layer
Output Junctions Feature Class
The updated Utility Network Pipeline Junction feature class.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
