Overlay Events (Linear Referencing Tools)
Summary
Overlays one or more line and point event layers onto a target network and outputs a feature class or table that represents the dynamic segmentation of the inputs.
Illustration
Overlay Events tool illustration
Usage
  • The following table is the output for the tool illustration above:
    Output (Overlay Events)
    Type
    From Measure
    To Measure
    Line Event 1
    Line Event 2
    Point Event
    Line
    A
    <Null>
    Point
    A
    PE1
    Line
    A
    <Null>
    Line
    B
    <Null>
    Line
    B
    <Null>
  • The Event Layers parameter values can be either line events only or can include both point and line events.
  • The Event Layers parameter can only include event feature classes registered with an LRS Network.
  • If the input layer has address range fields from an Address Data Management configuration and is configured as an Address Range feature class in an LRS, the values in the address range fields will be updated for each segment in the output proportionally when the Address Block Split Type parameter value is Proportional. When the parameter value is Nearest Address Point, address ranges will be updated for each segment in the output based on the nearest upstream and downstream address points.
    Learn more about analysis capabilities in a combined LRS and Address Data Management dataset
  • If the input event layers use different linear referencing methods (LRM), they will be translated using the LRM of the target network.
  • This tool supports selection sets and definition queries on the Input Route Features and Event Layers parameter values.
    To include all event records associated with the input routes, turn off the Use the selected records or the Use the filtered records toggle button for each input event layer.
  • This tool supports input event layers that are configured to contain events that span multiple routes. The output will still dynamically segment at the route level of the target network using the Network Fields parameter value.
  • This tool supports temporal segmentation (time slicing). This will occur by default and can be overridden by creating a time-based definition query or applying a selection set to the inputs.
  • This tool supports the inclusion of one or more fields from the network feature class in the output using the Network Fields parameter.
  • The output can be saved as either a table or a feature class.
  • If the output is saved as a table or feature class, the output will have the following indexes and fields:
    Index
    Field
    route_id
    • Route_ID
    rid_dates_measures
    • Route_ID
    • From_Date
    • To_Date
    • From_Measure
    • To_Measure
  • If more than one LRS Network exists in a Utility Network configuration, the measures for the input event layers will match the measures shown in the second column of the following table:
    If the LRS with the Utility Network configuration contains
    The measures in the Pipeline Line feature class belong to
    Line network, nonline network
    Line network
    Line network
    Line network
    More than one line network
    Line network that has the derived network
    More than one line network with no derived network
    Line network that has the lowest number in the coded-value domain dLRSNetworks
    More than one line network with derived networks
    One nonline network
    Nonline network
    More than one nonline network
    Network that has the lowest number in the coded-value domain dLRSNetworks
  • This tool supports physically gapped routes and events as input routes and input events, respectively.
  • Only one event per layer can be on a route segment. For example, for a layer named Speed Limit, only one event record in that layer can be on that segment. A segment can have multiple events, each in its own event layer. Use the ArcGIS Data Reviewer Invalid Event Measures check to identify and resolve issues with event data.
  • When running this tool with data from a feature service, if you experience failures or slower performance than expected, increase the heap size at the service level.
  • The Parallel Processing Factor environment setting for this tool applies only to events that span multiple routes and nonspanning events that are not registered with the target network.
Parameters
Label Explanation Data type
The target network onto which the event layers will be dynamically segmented.
Feature Layer
Event Layers
The event layers that will be dynamically segmented together onto a target network. The centerline layer can be used as an input to dynamically segment events.
Feature Layer
Output Dataset
The table or feature class containing the output event records that will be created.
Table
Include Geometry
(Optional)
Specifies whether the Output Dataset parameter value will include event geometry.
  • Checked—The Output Dataset parameter value will include event geometry. Event records will be stored as a feature class.
  • Unchecked—The Output Dataset parameter value will not include event geometry. Event records will be stored as a table. This is the default.
Boolean
Network Fields
(Optional)
The fields from the network layer that will be included in the output.
Field
(Optional)
Specifies how address ranges will be updated for each segment of the output.
This parameter is only available when you specify a configured Address Range layer as an input to the Event Layers parameter.
  • Nearest Address Point—Address ranges will be updated for each segment in the output based on the nearest upstream and downstream address values.
  • Proportional—Address ranges will be updated for each segment in the output proportionally from the split location. This is the default.
String
Environments
Current Workspace, Parallel Processing Factor
Special cases
The default value for this environment, if left blank, is 0%. Any absolute value for the environment is always clamped between 0 and the number of logical cores on your machine.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
