Configure Lookup Table (Linear Referencing Tools)
Summary
Configures a lookup table for one or more fields used in a multifield route ID.
This tool can be run after Create LRS Network From Existing Dataset or Modify LRS Network for a multifield route ID.
Learn more about creating the LRS, networks, and events
A lookup table is an alternative to using coded value domains when a field that makes up a multifield route ID has several hundred or thousands of potential values, for example, a list of street names or a Geographic Names Information System (GNIS) code. The lookup table is used primarily when creating a route.
Usage
The lookup table can be configured with both the Lookup Key and Lookup Display parameter fields, allowing you to search for a key value using its display value:
The
Lookup Keyfield is the value that will be saved for the field in the multifield route ID.The
Lookup Displayfield is the value that appears in the text box for the multifield route ID.
The Field Applied To parameter drop-down menu will display only the fields that make up a multifield route ID for the chosen LRS Network.
The
Lookup KeyandLookup Displayfields can be the same or different fields in the lookup table.The Lookup Key parameter drop-down menu will display only the fields from the lookup table that have the same field type and a length less than or equal to the Field Applied To parameter value.
The Lookup Display parameter value is optional. If you want to allow a value that is not in the lookup table, you cannot configure the Lookup Display parameter.
This tool only reads the lookup table and will not add records to it. If the desired value is not present, you can add it to the lookup table using this tool.
If padding is configured for the field, it will be added if the
Lookup Keyfield value is shorter than the field length.If the lookup table is in an enterprise geodatabase, it must be nonversioned.
Parameters
| Label | Explanation | Data type |
LRS Network Feature Class |
The input LRS Network feature class in which the lookup table will be configured. The network must have a multifield route ID. |
Feature Layer |
Lookup Table |
A table that contains a list of street names and their corresponding GNIS codes. It can be a stand-alone table or reside in an enterprise geodatabase. |
Table View |
Field Applied To |
The route ID field in the LRS Network in which the lookup table will be configured. |
String |
Lookup Key |
The key field in the lookup table. |
String |
Lookup Display (Optional) |
The lookup table description field. This field appears in the text box for the multifield route ID. |
String |
Allow any lookup value (Optional) |
Specifies whether a value that is not in the lookup table can be added. The Lookup Display parameter cannot be configured when this option is checked.
Boolean |
Derived output
Output Network Feature Class |
The updated route network feature class with a lookup table configured. |
Feature Layer |
Environments
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
