Generate Events (Linear Referencing Tools)
Summary
Regenerates shapes for event features registered with an LRS Network.
Usage
  • An LRS dataset is required to run this tool.
    Learn more about creating an LRS dataset
  • Use the event whose features need to be regenerated based on the route and measure of the event as input.
  • This tool supports conflict prevention and will attempt to acquire and transfer locks.
    Learn more about conflict prevention in ArcGIS Linear Referencing
  • When conflict prevention is enabled for the tool, any events being generated by the tool will be locked.
    • While working in the default version, the locks acquired are released automatically when the tool completes.
    • While working in a named version, the locks acquired remain in On Post status when the tool completes. The lock owner must post or delete the version to release the locks.
    • While working in a named version, if the tool run is canceled by interruption, the locks are acquired and remain in a releasable state after the tool completes.
  • When the Bypass events with null route ID and measure fields parameter is checked, the following are supported:
    • The shapes and attributes of event features with null route ID and measure fields remain unchanged.
    • The tool will provide a text file of event features that are bypassed.
Parameters
Label Explanation Data type
Event Layer
The event for which shapes will be regenerated.
Feature Layer
(Optional)
Specifies whether event features with null route ID and measure fields will be bypassed.
This parameter is only available in a combined LRS and Utility Network deployment.
  • Checked—Event features with null route ID and measure fields will be bypassed.
  • Unchecked—Event features with null route ID and measure fields will not be bypassed. This is the default.
Boolean
Derived output
Output Event Layers
The updated events feature layer.
Validation results for this tool are written to the ArcGIS Server directory. This file is automatically cleaned up in 10 minutes by default, which may not be enough time to process all of the validations and write them to your workstation that is running ArcGIS Pro. For larger data loads, it is recommended that you adjust the maximum file age to at least one hour.
Feature Layer
Output Results File
A text file that details changes made by the tool.
Text File
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
