Generate Linear Referenced Route Log (Linear Referencing Tools)
Summary
Creates a route log data product for routes in an LRS Network without an LRS data template.
Usage
  • This tool supports data from a file geodatabase, an enterprise geodatabase (branch versioned connection), or a feature service (published from branch versioned data).
  • This tool does not modify the inputs and will create a .csv file or a geodatabase table as the output.
  • The Effective Date parameter is used to define the temporal view of the network. Only routes active on this date will be used to calculate the output.
  • The log layers, location layers, and referent layers must be stored in the same geodatabase or feature service and have the same coordinate system as the specified LRS Network.
  • The log layer can be an LRS point event feature class, an LRS line event feature class, or an LRS intersection feature class that is registered to the specified LRS Network. A centerline feature class can also be used as a log layer when it is configured with the Address Data Management solution or a utility network.
  • The location layer must be a polygon feature class.
  • The output will be created based on the intersection of selected features from the LRS Network, log layer(s), location layer(s), and referent layer.
  • The referent layer must be an LRS point event feature class or an LRS intersection feature class that is registered to the specified LRS Network.
  • A value of unclassified will be included in the output location fields for routes that do not overlap with the location layers.
  • You can add multiple log and location fields from the same feature class by creating selection layers and specifying each selection layer as either a log field or a location field. For example, if you have an LRS line event feature class, you can create two selection layers—Class A and Class B—and specify each selection layer as a log field.
Parameters
Label Explanation Data type
Input Route Features
The route features that will be used to generate the route log.
Feature Layer
Effective Date
The date that will be used to define the temporal view of the network.
The default value is today's date.
Date
Log Fields
(Optional)
The fields that will be used to show event and intersection information in the output.
Value table columns:
  • Layer—The feature layer that will be used as the log layer.
  • Field—The field that will participate in the route log.
Value Table
Merge coincident events
(Optional)
Specifies whether coincident line events will be merged in the output.
  • Checked—Coincident line events with the same value in the log field will be merged and returned as a single event.
  • Unchecked—Coincident line events with the same value in the log field will not be merged or returned as a single event. This is the default.
Boolean
Location Fields
(Optional)
The fields used to show the attributes of the polygon boundaries crossed by the routes.
  • Layer—The feature layer that will be used as the location layer.
  • Field—The field that contains the attributes of the polygon boundaries crossed by the routes.
Value Table
Referent Location
(Optional)
Specifies the method that will be used to calculate the referent offset.
  • None—The referent offset will not be calculated. This is the default.
  • Nearest Upstream—The nearest referent feature upstream of the route log entry will be used to calculate the referent offset. If no upstream referent feature exists, the referent values will be empty.
  • Nearest—The nearest referent feature, upstream or downstream of the route log entry, will be used to calculate the referent offset.
String
Referent Features
(Optional)
The feature layer that will be used to calculate the offset from the route log entry.
Feature Layer
Referent Field
(Optional)
The referent field that will contain the attributes of the referent features in the output.
Field
Offset Units
(Optional)
Specifies the offset units that will be used to calculate the distance between the referent feature and the route log entry.
  • Inches (US Survey)—The units will be inches.
  • Feet (US Survey)—The units will be feet.
  • Yards (US Survey)—The units will be yards.
  • Miles (US Survey)—The units will be miles.
  • Nautical Miles (US Survey)—The units will be nautical miles.
  • Feet (International)—The units will be international feet. This is the default.
  • Statute Miles—The units will be statute miles.
  • Millimeters—The units will be millimeters.
  • Centimeters—The units will be centimeters.
  • Meters—The units will be meters.
  • Kilometers—The units will be kilometers.
  • Decimeters—The units will be decimeters.
String
Output Format
(Optional)
Specifies the format of the output.
  • CSV—The output will be a .csv file. This is the default.
  • Table—The output will be a geodatabase table.
String
Output File
(Optional)
The output .csv file that will contain the route log.
File
Output Table
(Optional)
The output geodatabase table that will contain the route log.
Table
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
