Create Template From Network Dataset (Network Analyst Tools)
Summary
Creates a file containing the schema of an existing network dataset. This template file can then be used to create a new network dataset with the same schema.
Usage
- This tool creates a network template file (
.xml) containing the schema of an existing network dataset. Use the Create Network Dataset From Template tool with this schema to make a new network dataset.
Parameters
| Label | Explanation | Data type |
Network Dataset |
The network dataset whose schema will be written to the output template file. |
Network Dataset Layer |
Output Network Dataset Template |
The output file ( |
File |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
