Create Network Dataset From Template (Network Analyst Tools)
Summary
Creates a new network dataset with the schema contained in the input template file (.xml). All the feature classes and input tables required for creating the network dataset must already exist before this tool is executed.
Usage
  • This tool creates a new network dataset using the schema from the template file. Use the Create Template From Network Dataset tool to create the schema for the new network dataset. The name of the output network dataset is specified in the input template file.
  • The newly created network dataset will need to be built using the Build Network tool.
Parameters
Label Explanation Data type
Network Dataset Template
The template file (.xml) created by the Create Template From Network Dataset tool containing the schema of the output network dataset to be created.
File
Output Feature Dataset
The feature dataset containing the feature classes that will take part in the network dataset being created. The network will be created in this dataset using the name specified in the network dataset template.
Feature Dataset
Derived output
Output Network
A new network dataset with the schema contained in the template file.
Network Dataset
Environments
Current Workspace
Licensing information
  • Basic: Requires Network Analyst
  • Standard: Requires Network Analyst
  • Advanced: Requires Network Analyst
