Share As Route Layers (Network Analyst Tools)
Summary
Shares the results of network analyses as route layer items in a portal. A route layer includes all the information for a route such as the stops assigned to the route or the orders serviced by a route, as well as the travel directions.
A route layer item can be used by various applications, such as ArcGIS Navigator to provide route guidance for mobile workers, the Directions pane in Map Viewer Classic to further customize the route contained in the route layer, and ArcGIS Pro to create a route analysis layer from a route layer.
Usage
  • The tool creates and shares the route layer items in the portal that is designated as the active portal. The active portal must be ArcGIS Online or ArcGIS Enterprise 10.5.1 or later.
  • The user that is signed in to the active portal must have the necessary privileges to run spatial analysis and create content.
  • If a route layer item with the same name exists in the specified folder, a new item with the same name will be created. One way to avoid creating duplicate items is to use a unique Route Name Prefix value when creating route layers using this tool.
  • The maximum number of route layers that can be created is 1,000. If the input route data contains more than 1,000 routes, the task will fail with an error message.
Parameters
Label Explanation Data type
Input Network Analysis Layer or Route Data
The network analysis layer from which the route layer items will be created. The network analysis layer should already be solved.
Route, Closest facility, Vehicle routing problem, and Last mile delivery network analysis layers are supported as valid inputs to this parameter.
The input can also be a .zip file containing route data created by the saveRouteData() method of the arcpy.nax solver result objects or the service parameter in the REST API that return a zipped geodatabase of route data with the correct schema.
File; Network Analyst Layer
Summary
(Optional)
The summary that will be used by the route layer items. The summary is displayed as part of the item information for the route layer item. If no value is provided, default summary text—Route and directions for <route name>—is used in which <route name> is replaced with the name of the route represented by the route layer.
String
Tags
(Optional)
The tags that will be used to describe and identify the route layer items. Individual tags are separated with commas. The route name is always included as a tag even when no other value is provided.
String
Route Name Prefix
(Optional)
A qualifier that will be added to the title of every route layer item. For example, a route name prefix of Monday morning deliveries can be used to group all route layer items created from a route analysis performed by deliveries that will be run on Monday morning. If no value is specified, the title of the route layer item will be created using only the route name.
String
Portal Folder Name
(Optional)
The folder in your personal online workspace where the route layer items will be created. If a folder with the provided name does not exist, a folder will be created. If a folder with the provided name exists, the items will be created in the existing folder. If no value is provided, the route layer items will be created in the root folder of your online workspace.
String
Share with
(Optional)
Specifies who can access the route layer items.
  • Everyone (public)—The route layer items will be public and can be accessed by anyone with the URL to the items.
  • Not shared—The route layer items will only be shared with the owner of the item (the user connected to the portal when the tool is run). As a result, only the item owner can access the route layers. This is the default.
  • These groups—The route layer items will be shared with groups the connected user belongs to and its members. The groups are specified using the groups parameter.
  • Organization—The route layer items will be shared with all authenticated users in your organization.
String
Groups
(Optional)
The list of groups with which the route layer items will be shared. This parameter is applicable only when the Share with parameter is set to These groups.
String
Derived output
Route Layer Items
Route layer items shared in a portal.
String
Environments
Output Coordinate System
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
