An overview of the Analysis toolset
The Analysis toolset contains tools used to perform analysis when using the ArcGIS Network Analyst extension. The toolset contains a variety of tools, including tools to create a network analysis layer and set its analysis properties for each solver provided with Network Analyst, tools to add network analysis objects to one or more network analysis classes, a tool to solve an analysis, and a tool to generate driving directions.
Tool
Add Field To Analysis Layer
Adds a field to a sublayer of a network analysis layer.
Add Locations
Adds input features or records to a network analysis layer. The inputs are added to specific sublayers such as stops and barriers. When the network analysis layer references a network dataset as its network data source, the tool calculates the network locations of the inputs, unless precalculated network location fields are mapped from the inputs.
Add Fleet Routing Breaks
Creates breaks in a Vehicle Routing Problem (VRP) layer.
Add Fleet Routing Routes
Creates routes in a vehicle routing problem, last mile delivery, or waste collection analysis layer. This tool will append rows to the Routes sublayer and can add rows with specific settings while creating a unique name field.
Calculate Locations
Locates input features on a network and adds fields to the input features that describe the network locations. The tool is used to precalculate the network locations of inputs that will be used in a Network Analyst workflow, improving performance of the analysis at solve time. The tool stores the calculated network locations of the inputs in fields in the input data.
Copy Network Analysis Layer
Copies a network analysis layer to a duplicate layer. The new layer will have the same analysis settings and network data source as the original layer and a copy of the original layer's analysis data.
Copy Traversed Source Features
Creates two feature classes and a table, which together contain information about the edges, junctions, and turns that are traversed while solving a network analysis layer.
Delete Network Analysis Layer
Deletes a network analysis layer and its analysis data.
Directions
Generates turn-by-turn directions from a network analysis layer with routes. The directions can be written to a file in text, XML, or HTML format. If you provide an appropriate style sheet, the directions can be written to any other file format.
Make Closest Facility Analysis Layer
Makes a closest facility network analysis layer and sets its analysis properties. A closest facility analysis layer is useful in determining the closest facility or facilities to an incident based on a specified travel mode. The layer can be created using a local network dataset or a service hosted online or in a portal.
Make Last Mile Delivery Analysis Layer
Creates a last mile delivery network analysis layer and sets its analysis properties. A last mile delivery analysis layer is useful for optimizing a set of routes using a fleet of vehicles. The layer can be created using a local network dataset or a service hosted online or in a portal.
Make Location-Allocation Analysis Layer
Makes a location-allocation network analysis layer and sets its analysis properties. A location-allocation analysis layer is useful for choosing a given number of facilities from a set of potential locations so that a demand will be allocated to facilities in an optimal and efficient manner. The layer can be created using a local network dataset or a service hosted online or in a portal.
Make OD Cost Matrix Analysis Layer
Makes an origin destination (OD) cost matrix network analysis layer and sets its analysis properties. An OD cost matrix analysis layer is useful for representing a matrix of costs going from a set of origin locations to a set of destination locations. The layer can be created using a local network dataset or a service hosted online or in a portal.
Make Route Analysis Layer
Makes a route network analysis layer and sets its analysis properties. A route network analysis layer is useful for determining the best route between a set of network locations based on a specified network cost. The layer can be created using a local network dataset or a routing service hosted online or in a portal.
Make Service Area Analysis Layer
Makes a service area network analysis layer and sets its analysis properties. A service area analysis layer is useful in determining the area of accessibility within a given cutoff cost from a facility location. The layer can be created using a local network dataset or a routing service hosted online or in a portal.
Make Vehicle Routing Problem Analysis Layer
Creates a vehicle routing problem (VRP) network analysis layer and sets its analysis properties. A VRP analysis layer is useful for optimizing a set of routes using a fleet of vehicles. The layer can be created using a local network dataset or a service hosted online or in a portal.
Make Waste Collection Analysis Layer
Creates a waste collection network analysis layer and sets its analysis properties. A waste collection analysis layer is useful for optimizing a set of routes using a fleet of vehicles to pick up municipal waste. The layer can be created using a network dataset.
Share As Route Layers
Shares the results of network analyses as route layer items in a portal. A route layer includes all the information for a route such as the stops assigned to the route or the orders serviced by a route, as well as the travel directions.
Solve
Solves the network analysis layer problem based on its input data and analysis settings. The solve output is added to the network analysis layer and can be examined in the map and attribute tables and used for further analysis.
Update Fleet Routing Assignments
Reassigns or unassigns selected stops in a waste collection analysis and updates the analysis results based on the updated route assignments.
Update Fleet Routing Results
Updates the results of a waste collection analysis to incorporate manual edits that reflect local knowledge and specific needs. The tool updates the metrics, directions, and reports when the route assignments are manually updated.
Tools in the Analysis toolset
Legacy:
The following tools were available in a previous version of ArcGIS Pro but have been deprecated:
Deprecated tool
Recommendation
Make Closest Facility Layer
Use the Make Closest Facility Analysis Layer tool.
Make Location-Allocation Layer
Use the Make Location-Allocation Analysis Layer tool .
Make OD Cost Matrix Layer
Use the Make OD Cost Matrix Analysis Layer tool.
Make Route Layer
Use the Make Route Analysis Layer tool.
Make Service Area Layer
Use the Make Service Area Analysis Layer tool.
Solve Vehicle Routing Problem
Use the Make Vehicle Routing Problem Analysis Layer tool and the Vehicle Routing Problem button in the Network Analysis drop-down menu on the Analysis ribbon.
Update Analysis Layer Attribute Parameter
Instead of creating a network analysis layer and using this tool to update its attribute parameters, preconfigure the attribute parameters when you set up the network dataset's travel modes.
Related tools
After performing network analysis using the Solve tool, you can use the results with other geoprocessing tools for further analysis. For example, after finding a five-minute drive-time polygon around a store location using service area analysis, you can find the customers of a particular age group that live within this area for mailing marketing materials. Use the Select Data tool to select only the polygons from the service area network analysis layer, the Select Layer By Location tool to find the customers, and the Copy Features tool to create a feature class with the list of customers.
