Closest facility analysis layer
This topic describes the closest facility analysis layer's feature classes and analysis properties.
Learn more about the closest facility solver
Learn more about network analysis layers
Facilities feature class
The Facilities feature class stores the network locations that are used as the starting or ending points in closest facility analyses.
When a closest facility analysis layer is created, the Facilities class is empty. It is populated only when network locations are added to it. A minimum of one facility and one incident are necessary to solve the analysis.
Facilities: Input fields
Input field |
Description |
Data type |
The system-managed ID field. |
Object ID |
The geometry field indicating the geographic location of the network analysis object. |
Geometry |
The name of the network analysis object. |
Text |
(for instance, |
This property stores an extra cost for the network location. Take the example of finding the three closest fire stations to a fire incident using |
Double |
(for instance |
While searching for the closest incident from a facility, Network Analyst can use a cutoff value for the impedance. Any incident beyond the cutoff value is not searched. If the |
Double |
Network location fields
Together, these properties describe the point on the network where the object is located. |
The
Learn more about U-turns and curb approach For closest facility analyses, the |
Long |
Facilities: Input/output fields
Input/output field |
Description |
Data type |
Specifies the status of the point with respect to its location on the network and the outcome of the analysis. The possible values are the following:
If a facility is not included in the solution because of specified cutoffs or a designated number of facilities to find, the status does not update to |
Long |
Incidents feature class
The Incidents feature class stores the network locations that are used as starting or ending points in closest facility analyses. Whether starting or ending points, incidents are always on the opposite end of a route from the connected facility.
When a closest facility analysis layer is created, the Incidents class is empty. It is populated only when network locations are added to it. A minimum of one facility and one incident are necessary to solve the analysis.
Incidents: Input fields
Input field |
Description |
Data type |
Object ID |
Geometry |
Text |
This property stores the number of facilities that need to be found for the incident. A default value for the number of facilities to find can be set on the Closest Facility Layer tab for this analysis layer. Values specified in the |
Long |
(for instance, |
This property stores an extra cost for the network location. For example, if you're finding the three closest fire stations from a fire incident using |
Double |
(for instance |
This cutoff value indicates the farthest network distance to search for a facility. Any incident farther from the facility than the cutoff value is not searched or included in the results. A default value for the cost cutoff can be set on the Closest Facility Layer tab for this analysis layer. Values specified in the |
Double |
The
Long |
Incidents: Input/output fields
Input/Output field |
Description |
Data type |
Long |
Routes feature class
The Routes feature class stores the resulting route, or routes, of the analysis. It is an output-only class; the closest facility analysis layer overwrites or deletes any route features while running the analysis.
Routes: Output fields
Output field |
Description |
Data type |
Object ID |
Geometry |
The name of the closest facility route is based on the names of the associated facility and incident. The facility name is first if the direction of travel is from the facility to the incident. For example, Facility 5–Incident 3 indicates the route travels from Facility 5 to Incident 3. The incident name is first if the direction of travel is from the incident to the facility. |
Text |
The unique ID of the facility the route visits. |
Long |
The rank of the facility among all facilities found for the associated incident; the closest facility has a rank of 1. |
Long |
Describes the side of the vehicle the incident is on when arriving at or departing from the incident. A value of 1 means the right side of the vehicle; a value of 2 indicates the left side. |
Long |
Describes the side of the vehicle the facility is on when arriving at or departing from the facility. A value of 1 means the right side of the vehicle; a value of 2 indicates the left side. |
Long |
The unique ID of the incident the route visits. |
Long |
(for instance |
The cumulative cost of the route between the facility and the incident. This field is generated for the impedance attribute and any accumulated attributes. |
Double |
The start time of the route, reported as local time at the first stop. |
Date |
The end time of the route, reported as local time at the last stop. |
Date |
The start time of the route in coordinated universal time (UTC). |
Date |
The end time of the route in coordinated universal time (UTC). |
Date |
Closest facility analysis layer properties
The following subsections list parameters you can set on the analysis layer. They are found on the Closest Facility Layer tab, which is available only if your Closest Facility layer or one of its sublayers is selected in the Contents pane.
Analysis
Use the options in this section to estimate the credits and run the analysis.
Run
Once you load input features and set analysis properties, click the Run button to run the analysis. If the analysis uses credits, and the number of credits estimated for the solve exceeds the available credits, an error message appears that blocks the solve or a warning message that allows you to choose whether to proceed with the solve.
The run button may appear different based on the source of the network dataset.
—The network analysis layer is referencing a local network data source.
—The network analysis layer is referencing a network data source in ArcGIS Online.
—The network analysis layer is referencing a network data source in an ArcGIS Enterprise portal.
Estimate Credits
You can use the Estimate Credits button to estimate the number of service credits that will be consumed by running the analysis on the selected network analysis layer. When this button is enabled, it indicates that the network analysis layer will consume credits when solved.
The Estimate Credits button is enabled when the following occur:
The network analysis layer's network data source is hosted in ArcGIS Online.
Your ArcGIS Enterprise portal routing services are configured from ArcGIS Online.
The Estimate Credits button is disabled when the following occur:
The network analysis layer's network data source is stored on a local machine.
You're using your own services published on your ArcGIS Enterprise portal.
When you click the Estimate Credits button, a dialog box appears with an estimate of the number of credits that are likely to be consumed solving the current analysis. The credit estimate is based on the number of input locations used in the analysis. The actual credits consumed may change based on the output generated by the Solve operation. Depending on how your organization has set up the credit budgeting and allocation settings, the available credits may not be shown. Also, credit estimation may not always be possible if the network data source is an ArcGIS Enterprise portal with routing services configured from ArcGIS Online.
Learn more about the credit usage by each analysis type
Depending on the configuration of the ArcGIS Online organization account and the signed-in user, solving the analysis may be blocked or may show a warning if the estimated credits exceed the available credits.
Input Data
Use the options in this section to import the input features to participate in the analysis.
Import Facilities
Use Import Facilities
to load features from another data source, such as a point feature layer, into the Facilities feature class.
Import Incidents
Use Import Incidents
to load features from another data source, such as a point feature layer, into the Incidents feature class.
Import Barriers
Use the Import Point Barriers
, Import Line Barriers
, or Import Polygon Barriers buttons
to load features from another data source, such as another feature layer, into one of the barriers feature classes (point barriers, line barriers, or polygon barriers).
Create Features
Use the Create Features button
to open the Create Features pane. Select from the available templates to create features in the current map.
Explore Locations
The Explore Locations tool helps to visualize on the map where an input point was located on the network or if not located at all.
Learn more about Explore Locations
Travel Settings
Use the options from this section to select the travel mode, travel direction, cutoff, and number of facilities.
Mode
Use the Mode drop-down list to choose a travel mode, which is a group of settings that together model the movement of pedestrians, cars, trucks, or other travel mode. The choices available in the drop-down list depend on the travel modes that are configured on the network data source that the network analysis layer is referencing.
Direction
Your closest facility analysis can accumulate travel time or other cost in the direction away from or toward the facilities.
Away from facilities
—The direction of travel is from the facility to the incident.Toward facilities
—The direction of travel is from the incident to the facility.
On a network with one-way restrictions and different travel times based on direction of travel, changing the travel direction can produce different results. The direction you should choose depends on the nature of your analysis. For example, to route the closest fire truck (the facility) to the location of a fire (the incident), the Away from facilities option is the most appropriate choice. Alternatively, to identify the closest gas station (facility) to your current location, Toward facilities is a better choice because you need to travel to the facility.
The direction setting affects how Network Analyst interprets the time and date you specify in the Arrive/Depart Date-Time Type, Time of Day, and Date controls.
Time Usage: Departure
—When the travel direction is set as Away from facilities, the time and date indicate the route starts at the facility.Time Usage: Arrival
—When the travel direction is set as Toward facilities, the time and date indicate the arrival time at the facility.
Cutoff
When calculating the least-cost path from an incident to a facility, the Closest Facility solver stops searching for facilities that lie beyond this impedance cutoff. No facilities beyond this limit are found for that incident. The units you use for the cutoff value are shown next to the Mode drop-down list.
Cutoff assigns default values to origins that do not have numeric values stored in the Cutoff_[Cost] field.
Accumulate Cost Attributes
The Accumulate Cost Attributes drop-down menu
can be used to configure accumulated cost attributes. The drop-down menu is unavailable if the network data source is a service, the output geometry types do not include lines, or there are no cost attributes. The attributes are grouped by unit domain shown as the group header (for example, Time or Distance). A checked check box indicates that the analysis layer will accumulate the checked attribute during the solve.
When multiple analysis layers of the same layer type are selected, the check box shows a mixed state if all layers do not share the same checked status for one attribute. In the following image, the WeekendFallbackTravelTime attribute is selected for multiple layers, so it has a check mark:
If all selected layers share the checked status for an attribute, the check box shows that state:
Facilities
You can specify the number of facilities to find per incident by entering a value for Facilities or use the controls to specify a value.
The Facilities value can be overridden on a per-incident basis by specifying an individual value for the TargetFacilityCount property in the incidents sublayer.
Date and Time
Use the options from the Date and Time section to specify the date, time, and day to be used in the analysis.
Learn more about date and time
Time Usage
You can choose the specified date and time to be either the departure time or arrival time.
—Represents the date and time you want the closest facility routes to start.
Time Usage: Arrival
—Represents the date and time you want the closest facility routes to finish.
Arrive Depart Date-Time Type
The Arrive Depart Date-Time Type drop-down list is available when the cost units are time based. From the drop-down list, choose whether a specific time and date value is given to indicate the time that the route starts or ends. The primary reason for setting a specific time and date is to solve the analysis using dynamic traffic conditions or public transit schedules; however, to use traffic or public transit in the analysis, the network dataset or route service must include traffic data or public transit.
The options in the drop-down list are as follows:
Not Using Time—Regardless of whether the network data source includes time-based data, the results are based on static travel times—the travel times on a network edge don't vary throughout the day. The Time of Day and Date text boxes are unavailable.
Date & Time—Specify the time as a time of day and calendar date. The Time of Day and Date text boxes are available to provide this information.
Day of Week—Specify a time of day and day of the week. The Time of Day and Date text boxes are available to provide this information.
Today—Specify a time, and the day is assumed to be the current date. The Time of Day text box is available to provide the time of day, and the Date text box is set to Today and is unavailable so it can't be changed.
Now—When you run the analysis, the time and date are set to the current time and date. This is useful if the network dataset is configured with live traffic data, and the routes are distributed to drivers for implementing immediately after running the analysis. The Time of Day and the Date text boxes are unavailable so they can't be changed.
Time of Day
Specify the depart time of the day.
See the Arrive Depart Date-Time Type section to see when this option is enabled.
Date
Specify the depart day of the week by typing one of the following values in the Date text box:
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Reference Time Zone
From the Reference Time Zone drop-down list
, you can choose the time zone to use in the analysis. The options are as follows:
Local Time at Locations
Coordinated Universal Time (UTC)
When routing across multiple time zones, be aware of the following:
All incidents must be in the same time zone when the following occur:
Specifying a start time and traveling from incident to facility
Specifying an end time and traveling from facility to incident
All facilities must be in the same time zone when the following occur:
Specifying a start time and traveling from facility to incident
Specifying an end time and traveling from incident to facility
Output Geometry
Use the options from the drop-down menu to choose how the output will display in the map.
Output Geometry Linear Shape Type
The closest facility analysis always solves least-cost paths along the network using the settings you specify. In addition to displaying these true paths along the network on the map, you can also choose to represent the routes on a map using simple straight lines between incidents and facilities or no lines at all.
No Lines—No output linear shapes are generated.
Straight Lines—Output simplified geometry as straight lines.
Along Network—Generate true paths along the network on the map.
Drawing
Use the Symbology button
to access the symbology pane for the active network analysis layer. You can configure the symbology for the sublayers of the active network analysis layer by choosing one of the following options:
Single Color—This option is available for all network analysis layer types. All feature sublayers in the active network analysis layer except barriers will use the same single symbol with the specified color. For example, choosing a single color of blue for a Route layer will convert all the Stops and Routes features to the same color of blue.
Color Linked—This option is available for Route, Last Mile Delivery, Vehicle Routing Problem, and Waste Collection analysis layers. It applies a color scheme to the sublayers such that related features are symbolized with the same color. This symbology configuration symbolizes related features with the same color, making it easier to visually distinguish different routes and their associated features in the map. For example, for a Route layer with multiple routes, each route and the stops assigned to that route will be assigned matching colors.
Learn more about network analysis layer symbology
Directions
Use the options from the Directions section to specify whether directions should be generated.
Output on Solve
Turn on this option to generate directions upon solve for the current network analysis layer.
Show Directions
When the Output on Solve option is checked, when you click the Show Directions button
, the Directions pane appears with turn-by-turn directions for each route in the solution.
Share As
Share the output of the analysis by using the available option of Route Layers.
Share as Route Layers
Use the Route Layers button
to share the results from the analysis as route layers. This button opens the Share as Route Layers geoprocessing tool. After it runs, the results from the analysis are shared as route layer items in the portal.
