Copy Network Analysis Layer (Network Analyst Tools)
Summary
Copies a network analysis layer to a duplicate layer. The new layer will have the same analysis settings and network data source as the original layer and a copy of the original layer's analysis data.
Usage
The tool makes a copy of the input network analysis layer's analysis data (the feature classes and tables referenced by the network analysis layer's sublayers and subtables). The layer's network data source is not copied.
The analysis data is copied to the Current Workspace environment. If this environment is not set, the data is copied to the same geodatabase that contains the analysis data for the input network analysis layer.
Parameters
| Label | Explanation | Data type |
Input Network Analysis Layer |
The network analysis layer to copy. |
Network Analyst Layer |
Output Layer Name (Optional) |
The name of the network analysis layer that will be created. |
String |
Derived output
Output Network Analysis Layer |
The newly created network analysis layer. |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
