Calculate Locations (Network Analyst Tools)
Summary
Locates input features on a network and adds fields to the input features that describe the network locations. The tool is used to precalculate the network locations of inputs that will be used in a Network Analyst workflow, improving performance of the analysis at solve time. The tool stores the calculated network locations of the inputs in fields in the input data.
Learn more about locating features on a network
Learn more about precalculating network locations
Usage
  • By default, this tool stores the calculated network locations in a set of fields with network location field names recognized by all Network Analyst workflows. However, you can change the names of the fields where the calculated network locations are stored. In this case, when using the precalculated network locations in a workflow, use field mapping to map the nondefault location fields to the correct network location properties.
    The only reason to change the field names is to store a separate set of location fields for different networks or travel modes in the same feature class. Otherwise, always use the default field names.
    Alternate field names can be specified using the Source ID Field, Source OID Field, Percent Along Field, Side of Edge Field, Located X-Coordinate Field, Located Y-Coordinate Field, Distance from Feature Field, Located Z-Coordinate Field, and Location Ranges Field parameters.
  • This tool only calculates the network locations of inputs using a network dataset. It cannot calculate network locations for a network analysis service.
  • If the input features are a sublayer of a network analysis layer, the Search Tolerance, Search Criteria, and Search Query parameters are automatically populated based on location properties stored in the input network analysis layer. If the network analysis layer has location settings overrides for the selected sublayer, those settings are used. Otherwise, the network analysis layer's default location settings are used.
    Learn more about a network analysis layer's location settings
  • If the input features are a sublayer of a network analysis layer and you change the value for the Search Tolerance, Search Criteria, or Search Query parameters, running the tool will update the network analysis layer's location settings overrides for the selected sublayer. Storing these location settings in the network analysis layer ensures that any automatic relocating done at solve time uses the same location settings you used when initially calculating network locations.
  • If the input feature class has a CurbApproach field of type Long, the values in this field may be used to influence locating behavior. In particular, if points locate on a one-way street and have a curb approach specifying the left or right side of the vehicle, the SideOfEdge location field value may be updated to ensure that the point can be reached in the correct direction along the one-way street. The CurbApproach field is not required in the input, but if it exists and is of type Long, it will be used.
    If a row has a CurbApproach field value that doesn't match one of the valid CurbApproach domain values, the field value for that row will be ignored when locating the point and the default value of 0 (either side of vehicle) will be used.
    Learn more about curb approach
  • If the input feature class has a Status field of type Long, the field's values will be updated to reflect each row's locating status.
    If the Status field in the input feature class is used for another purpose and you don't want it to be overwritten, change the field's name before running this tool.
Parameters
Label Explanation Data type
Input Features
The input features for which the network locations will be calculated.
For line and polygon features, since the network location information is stored in a BLOB field, only geodatabase feature classes are supported.
Table View
Input Analysis Network
(Optional)
The network dataset that will be used to calculate the locations.
This parameter is required unless a sublayer of a network analysis layer is used as input features. In that case, the parameter is hidden and automatically set to the network dataset referenced by the network analysis layer.
Network Dataset Layer
Search Tolerance
(Optional)
The maximum search distance that will be used when locating the input features on the network. Features that are outside the search tolerance will be left unlocated. The parameter includes a value and units.
The default is 5000 meters.
If the input features are a sublayer of a network analysis layer, the default value for this parameter is determined based on location properties stored in the input network analysis layer. If the network analysis layer has location settings overrides for the selected sublayer, those settings will be used. Otherwise, the network analysis layer's default location settings will be used. Setting a nondefault value for this parameter updates the network analysis layer's location settings overrides for the selected sublayer.
The parameter is not used when calculating locations for line or polygon features.
Linear Unit
Search Criteria
(Optional)
The edge and junction sources in the network dataset that will be searched when locating inputs on the network. For example, if the network dataset references separate feature classes representing streets and sidewalks, you can locate inputs on streets but not on sidewalks.
The default value is to locate on all network sources except override junctions created by running the Dissolve Network tool and system junctions.
Caution:
For a waste collection analysis, the solve operation will fail if any stops are located on junctions. Do not configure this parameter to allow locating on junction sources when adding stops to a waste collection analysis layer.
Value table columns:
  • Source—The edge and junction sources in the network dataset.
  • Snap Type—Specifies the snap type options for each network source.
    • None—The point will not locate on elements in this network source.
    • Shape—The point will locate on the closest point of an element in this network source.
    • Middle—This option is deprecated and behaves the same as Shape.
    • End—This option is deprecated and behaves the same as Shape.
Value Table
Find Closest among All Classes
(Optional)
Legacy:
This parameter is deprecated and maintained only for backward compatibility. Inputs will always be matched to the closest network source among all the sources used for locating, corresponding to a parameter value of MATCH_TO_CLOSEST or True.
  • Checked—Inputs are matched to the closest network source among all the sources used for locating.
  • Unchecked—This option is deprecated and maintained only for backward compatibility. Inputs are matched to the closest network source among all the sources used for locating.
Boolean
Source ID Field
(Optional)
The name of the field to be created or updated that will be populated with the ID of the network dataset source feature class for the input feature's computed network location. The default value is SourceID.
Do not use this parameter when the input features are a sublayer of a network analysis layer. Network locations in a sublayer must be stored in location fields with the default names or they will not be used when the layer is solved.
Field
Source OID Field
(Optional)
The name of the field to be created or updated that will be populated with the ObjectID field value of the network dataset source feature class for the input feature's computed network location. The default value is SourceOID.
Field
Percent Along Field
(Optional)
The name of the field to be created or updated describing the computed network location's percent along the network element where it was located. The default value is PosAlong.
Field
Side of Edge Field
(Optional)
The name of the field to be created or updated describing the side of the network edge where the computed network location is located. The default value is SideOfEdge.
Field
(Optional)
The name of the field to be created or updated with the x-coordinate of the computed network location. The default value is SnapX.
Field
(Optional)
The name of the field to be created or updated with the y-coordinate of the computed network location. The default value is SnapY.
Field
(Optional)
The name of the field to be created or updated describing the distance in meters of the original point feature from its computed network location. The default value is DistanceToNetworkInMeters.
Field
(Optional)
The name of the field to be created or updated with the z-coordinate of the computed network location. The default value is SnapZ.
The parameter is used only when the input network dataset supports connectivity based on z-coordinate values of the network sources.
Field
(Optional)
The name of the field to be created or updated with the location ranges of the computed network locations for line or polygon features. The default value is Locations.
The parameter is used only when calculating locations for line or polygon features.
Field
Exclude Restricted Portions of the Network
(Optional)
Legacy:
This parameter is deprecated and maintained only for backward compatibility. Analysis inputs will never be located on network elements that are restricted, corresponding to a parameter value of EXCLUDE or True.
  • Checked—Analysis inputs will never be located on network elements that are restricted.
  • Unchecked—This option is deprecated and maintained only for backward compatibility. Analysis inputs will never be located on network elements that are restricted.
Boolean
Search Query
(Optional)
A query that restricts the search to a subset of the features within a source feature class. This is useful if you don't want to find features that may be unsuited for a network location. For example, if you don't want to locate on highway ramps, you can define a query to exclude them. A separate SQL expression can be specified per edge or junction source feature class of the network dataset.
Any network source not explicitly specified in the Geoprocessing pane will have no query applied.
By default, no query is used for any source.
  • Name—The name of the network source.
  • Query—The SQL expression that will be used as the query for the source.
Value Table
Travel Mode
(Optional)
The name of the travel mode that will be used.
If you specify a travel mode, the travel mode settings, such as restrictions and impedance attributes, will be considered when calculating network location. For example, if the closest network edge to one of the input points is restricted when the selected travel mode is applied, the tool will locate the point on the next-closest network edge that is not restricted.
The available travel modes depend on the Input Analysis Network parameter value.
If a sublayer of a network analysis layer is used as input features, this parameter is hidden and should not be used. When network locations are calculated, the network analysis layer's current travel mode will automatically be used.
String
Derived output
Updated Input Features
The updated input features.
Table View
Network Analyst Layer
If the Input Features parameter value was a sublayer of a network analysis layer, this derived output parameter returns the sublayer's parent network analysis layer. Otherwise, no value is returned.
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
