Apply Grid Layout (Network Diagram Tools)
Summary
Positions diagram junctions relative to a predefined magnetic grid.
Learn more about the Grid layout algorithm
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Each layout algorithm includes default parameter values. The default parameter values will be used unless otherwise specified. If the input network diagram is based on a template for which this layout has been configured with a different parameter value, that value will be used instead.
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
  • This layout algorithm positions diagram junctions relative to a magnetic grid that has cell sizes fixed by the Cell Width and Cell Height parameter values.
  • A grid with a specified cell size is placed on the top of the diagram. The algorithm controls the number of cells that comprise a grid. This is calculated by factoring in the number of junctions that are going to be placed in the grid and the number of junctions that belong to each cell in the virtual grid.
  • When there are too many junctions in one or several virtual grid cells, the algorithm cannot complete the process and a warning appears advising you to decrease the grid cell size.
  • When the specified grid is composed of a large number of cells relative to the number of junctions to be placed in the grid, a warning appears advising you to increase the grid cell size.
  • Consider applying the layout in asynchronous mode on the server when working on very large diagrams.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The network diagram to which the layout will be applied.
Diagram Layer
Preserve container layout
(Optional)
Specifies how the layout algorithm will process containers.
  • Checked—The layout algorithm will apply to the top graph of the diagram so container layouts are preserved.
  • Unchecked—The layout algorithm will apply to both content and noncontent features in the diagram. This is the default.
Boolean
Cell Width
(Optional)
The width of each grid cell. The default is 2 in the units of the diagram's coordinate system.
Linear Unit
Cell Height
(Optional)
The height of each grid cell. The default is 2 in the units of the diagram's coordinate system.
Linear Unit
Run in asynchronous mode on the server
(Optional)
Specifies whether the layout algorithm will run asynchronously or synchronously on the server.
  • Checked—The layout algorithm will run asynchronously on the server. This option dedicates server resources to run the layout algorithm with a longer time-out. Running asynchronously is recommended for layouts that are time consuming and may exceed the server time-out (for example, Partial Overlapping Edges) and applying to large diagrams (more than 25,000 features).
  • Unchecked—The layout algorithm will run synchronously on the server. It can fail without completion if it exceeds the service default time-out value of 600 seconds. This is the default.
Boolean
Derived output
Output Network Diagram
The updated network diagram layer.
Diagram Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
