Change Diagrams Owner (Network Diagram Tools)
Summary
Changes ownership of stored network diagrams.
Caution:
This tool is an administration tool.
Legacy:
Change Diagrams Owner cannot process utility network datasets that were created prior to ArcGIS Pro 2.4, even if they have been upgraded.
Learn more about transferring ownership of network diagrams
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • Either the Diagram Names or Source Owner parameter must be specified to run the tool. The tool will fail if neither has been specified.
    • When no diagram names have been specified, any network diagram owned by the source owner will be transferred to the specified target owner.
    • When Diagram Names and Source Owner are both specified, the source owner is ignored and the ownership of each input network diagram will be transferred to the specified target owner regardless of the current owner.
  • The Source Owner and Target Owner values must be the owner of at least one stored network diagram in the dataset.
  • Diagram names specified in the Diagram Names parameter are not case sensitive.
  • When a network diagram layer is specified as input, it is only used to retrieve the related network; it doesn't impact the network diagram. The only exception is if the diagram name is referenced among the specified diagram names.
Parameters
Label Explanation Data type
Input Network or Network Diagram Layer
The input network layer or network diagram layer related to the utility network or trace network of interest with the stored network diagrams whose ownership will be transferred.
Utility Network Layer; Trace Network Layer; Utility Network; Trace Network; Diagram Layer
Target Owner
The name of the user that will become the new owner of the specified diagrams.
String
Source Owner
(Optional)
The name of the user whose ownership of the network diagrams will be changed.
This parameter is only used when there are no specified diagram names. When diagram names are specified, it will be ignored.
String
Diagram Names
(Optional)
The names of the diagrams to be processed.
String
Derived output
Output Network or Network Diagram Layer
The updated network or network diagram.
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
